Guy with CC305 or similar cams
Old Nov 30, 2003 | 07:12 PM
DamianLT1's Avatar
Exclamation Guy with CC305 or similar cams
Please post your HP ratings. I'm going to Dyno my car and see what I should get. Please also put what you have in the car, header, TB, et...
Old Nov 30, 2003 | 08:42 PM
DamianLT1's Avatar
c'on guys!!! I really need this data.
Old Nov 30, 2003 | 09:53 PM
12SCNDZ's Avatar
Well, I don't have any dyno numbers, but the 1320 ft. dyno is working out pretty well. With a CC305 in a stock 95,000 mile bottom end, and MAC headers, I've went 12.05 @ 112 MPH in crappy weather.
Frank
Old Nov 30, 2003 | 10:02 PM
94formulabz's Avatar
See, the stage II porting is throwing everyone off. There is no definition of Stage II porting. The heads are FAR more important than the cam. If they were stock heads you'd be looking at 330 rwhp. With some awesome LT1 heads 385 maybe, who knows. Can't say because Stage II doesn't mean much.
Frank has some decent heads if you go by peak numbers alone. He's probably around 350 rwhp sae based on his trap speed of 112, but his nonlockup converter is probably killing his hp peak and trap speed compared to someone with an M6 and less drivetrain loss but crappier 60' times and ETs.
sorry, not as easy to answer as you wished.
-brent
Old Dec 1, 2003 | 07:32 AM
DamianLT1's Avatar
tt
Old Dec 1, 2003 | 07:37 AM
DamianLT1's Avatar
I'm looking for more of DYNO data. Someone ported my heads and I think I should be around 350rwhp is they did it right. I don't think he did a good job at all. The Dyno number will prove if I'm right.
Old Dec 1, 2003 | 01:53 PM
stereomandan's Avatar
Most people that I've seen with your combo, minus the heads, get about 330-340 RWHP and about 340 RWTQ. With the heads, maybe add another 20 HP.
Dan
Old Dec 1, 2003 | 02:28 PM
DamianLT1's Avatar
It sure doesn't feel like its making anywhere near that.
Old Dec 1, 2003 | 03:27 PM
Are your rockers adjusted too tight?
You're throttle cable isn't stretched or loose is it? That could cause you not to be at WOT when you have the pettle to the floor.
Those were just a couple of ideas for you to think about.
Also, the A/F ratio that you will get from the dyno tune will help you understand what's going on.
Dan
Old Dec 1, 2003 | 04:21 PM
Projectz28's Avatar
Moderator
Dyno numbers in sig... not sure how much I belive them though.
cc305, stock heads, my own tune, Yank 3500 converter, LT's and cutout, all the usual bolt ons. Oh and the dyno and times were made with 3.73's in the back.
Old Dec 1, 2003 | 04:46 PM
DamianLT1's Avatar
Than project Z if you're running 11.91 with stock head I would assume those number are higher.
Rockers just got adjusted when the valve seals where replace.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Red97LT1
Aug 7, 2002 05:45 PM
