Which Guideplates To Buy ? ***Problem with my ISKY's***
Old Jul 29, 2008 | 10:30 AM
  #16
krillformula's Avatar
Originally Posted by HardcoreRM125
Well guys, I just ordered a set of Trickflows so I'll have them here tomorrow or Monday at the very latest. Convienently, I am off next week so I will have the car up and running again sooner than expected...
Now as long as these things ARE spaced correctly for an LT1 ... I should be good to go.
Thanks Guys!
Appreciate it ...
Did the Trickflows solve the ticking sound?
Old Jul 29, 2008 | 11:51 AM
  #17
HardcoreRM125's Avatar
I would 75% of the ticking is gone. Now I hear a slight tick from a couple of the rockers, but their Pro-Mags ... the ones on the racecar are loud too but their on a S.R. setup ...
Old Jul 29, 2008 | 11:53 AM
  #18
Also, these were centered pretty damn well over the valves. Better then the LT1 I seen with GM plates!
Old Jul 29, 2008 | 01:05 PM
  #19
mzgp5x's Avatar
I had the Isky guides but did not use them. I did not like the lateral slot under the stud. Looked like they could move. Ended up buying the gm standard flat from Summit. I also ran 7.3" long push rods with Comp 1.52 ProMag RR's. The RR's did not line up well over the valves (AFR heads). So, I cut them down the center and MIG welded them so the rockers would run on the valve tappet center. They been workin well for me with a CamMotion FI 231/240* - .538"/.560" lift.
Old Jul 29, 2008 | 02:21 PM
  #20
Ok because I also have a slight ticking sound that I dont want to hear, its annoying! But I already have the TF plates. But I suppose that is the way pro mags are..
KamikaZ28
May 28, 2015 12:45 AM
NewsBot
Jan 8, 2015 11:29 PM
Catmaigne
Dec 25, 2014 12:16 PM
