P0148
Old Jul 29, 2008 | 07:06 AM
Mir Hussain's Avatar
Lightbulb P0148
Where should I strart off ?
I know it is SAI releated
Old Jul 29, 2008 | 10:53 AM
Severous01's Avatar
start with a fuel pressure test...and regulator test...
then get back with us
and what does sai have to do with it??? sai is suspension and alignment related
Old Jul 29, 2008 | 11:56 AM
moparman's Avatar
Are you sure P0148 is the correct code?
Old Jul 29, 2008 | 03:44 PM
Talking
Well that is what it says! in HyperTech Scan Tool
Funny After work home drive where my car was getting cooked
It didn't turn AirPump on and I didn't get message
Let see what it does in morning where it is little bit cooler!
SAI=Secondry Air Injection
Old Jul 29, 2008 | 03:48 PM
BUBBA's Avatar
Drop by AutoZone. They will scan it for you and tell you what the code is.
Old Jul 29, 2008 | 03:51 PM
BUBBA's Avatar
...well maybe there is no AutoZone in Canada, but there must be some store/shop that will do it for free. Do you also have a hyper crap programer.
Old Jul 29, 2008 | 03:54 PM
moparman's Avatar
The reason I asked if that's the correct code is it's not listed in my OBDII book, nor is it listed on the GM site.
http://service.gm.com/gmspo/mode6/index.html
Old Jul 29, 2008 | 04:04 PM
Smile
yea
Old Jul 29, 2008 | 04:10 PM
BUBBA's Avatar
Unless you have an A-4, you might as well sell both the programmer and the scanner and treat yourself to a nice mail order tune. JMHO
Old Jul 29, 2008 | 04:12 PM
Arrow
It is already Program by PCM for Less
HyperTech is for Scan Tool!
Old Jul 29, 2008 | 04:26 PM
BUBBA's Avatar
Well then, you probably should do as suggested and chech your fuel pressure and make sure you are not running to lean before you really booger things up. Might consider changing fuel filter etc----anything that might be restricting your fuel flow. JMHO
Old Jul 29, 2008 | 05:10 PM
That code is not on Shoebox's LT1 list, not on the GM service site for the OBD-II LT1. The air injection system codes are P0410 and P0412. The OBD-II standards dictate that P0148 is for "Fuel Delivery Error", but in 10 years of working on these cars, I've never seen that code listed as applicable to the LT1.
