Guideplates...
Old Mar 11, 2004 | 06:00 AM
zet_power's Avatar
Guideplates...
Hi,
i'm kinda new to LT1 territory, looking for your advice...
Did any of aluminium LT1 heads come from factory with guideplates? I'm buying a set of 374 heads and they're equipped with gp's. Current owner doesn't know anything about 'em since he's bought the heads with guideplates already installed.
If there were gp's installed by GM then are they worth keeping or should I rather replace 'em with quality ones from Comp/Lunati/Crane? I remember L98 Corvette heads which had both SA rockers and crappy guideplates "for assembling purposes", thats why I'm asking this question...
When installing guideplates - is it necessary to mill some material off the stud bosses to compensate plate's thickness? How can I check if this has been done on "my" heads?
Sorry for multiple questions and thank you i. a.
Mike
Old Mar 11, 2004 | 06:58 AM
scoobysnax83's Avatar
GM did not put Guide Plates in any LT1 from the factory...
Old Mar 11, 2004 | 07:18 AM
zet_power's Avatar
OK, so now I know they're not installed by factory; thank you!
How about stud bosses? To mill or not to mill?
Old Mar 11, 2004 | 07:20 AM
Plus, the guideplates you should use are GM p/n 14011051. They will have "05" and "P" stamped on them. The "quality" ones are often the normal SBC plates that don't have the correct spacing for the LT1.
There is no need to remove any material from the head for LT1 guideplates.
Old Mar 11, 2004 | 07:21 AM
GetaZforgetGT's Avatar
I didn't mill mine when I installed them...no problems here.
I've never heard of anyone milling them in the past.
Old Mar 11, 2004 | 08:00 AM
zet_power's Avatar
Oops, I didn't even know about spacing issue... I'll check part number and symbols when I get the heads (grrr, two weeks and $2.04 per lbs...). Thanks To All Of You, Guys!
94_camm
Parts Wanted
Dec 16, 2006 11:16 AM
firebirdStud
Jun 13, 2006 07:55 PM
96LT1TX
Jan 22, 2004 05:54 PM
