Guideplates...
Guideplates...
Hi,
i'm kinda new to LT1 territory, looking for your advice...
Did any of aluminium LT1 heads come from factory with guideplates? I'm buying a set of 374 heads and they're equipped with gp's. Current owner doesn't know anything about 'em since he's bought the heads with guideplates already installed.
If there were gp's installed by GM then are they worth keeping or should I rather replace 'em with quality ones from Comp/Lunati/Crane? I remember L98 Corvette heads which had both SA rockers and crappy guideplates "for assembling purposes", thats why I'm asking this question...
When installing guideplates - is it necessary to mill some material off the stud bosses to compensate plate's thickness? How can I check if this has been done on "my" heads?
Sorry for multiple questions
and thank you i. a.
Mike
and thank you i. a.Mike
Originally posted by scoobysnax83
GM did not put Guide Plates in any LT1 from the factory...
How about stud bosses? To mill or not to mill?
There is no need to remove any material from the head for LT1 guideplates.
Oops, I didn't even know about spacing issue... I'll check part number and symbols when I get the heads (grrr, two weeks and $2.04 per lbs...). Thanks To All Of You, Guys!
firebirdStud
Jun 13, 2006 07:55 PM
96LT1TX
Jan 22, 2004 05:54 PM
