Guideplate wear. Replace?
Old Aug 20, 2010 | 01:25 PM
Rob94hawk's Avatar
Aquired these heads from Jason Short. The guideplates seem to be worn on all the intake sides. Replace? Thanx
Old Aug 20, 2010 | 01:32 PM
RamAir95TA's Avatar
Those look like the GMPP plates? Rumor has it that some of them are not hardened. A small amount of rubbing is acceptable, but gouging into the guideplate is not. I'd try the hardened Trick Flow plates 30400623-8. Also, when you install them make sure you center them over the rocker studs before tightening them down. This will help keep the geometry in alignment.
Old Aug 20, 2010 | 01:39 PM
Rob94hawk's Avatar
Summitracing is gonna love me this week....
Old Aug 20, 2010 | 02:11 PM
1badeagle's Avatar
Deffiently replace them with new better trickflows. Dont wanna have to replace something more costly down the road.
Dustin
Old Aug 21, 2010 | 02:44 AM
ACE1252's Avatar
I just switched from GM guideplates to the Trickflow plates. I had 3 of the GM plates that looked EXACTLY like your picture.
Old Aug 21, 2010 | 07:45 AM
wrd1972's Avatar
Happened to mine too. The next set of GM plates I got I hardened myself and not a spec of wear.
Old Aug 21, 2010 | 04:36 PM
Rob94hawk's Avatar
What hardened pushrods did you guys use? Trickflow as well?
Old Aug 21, 2010 | 04:40 PM
RamAir95TA's Avatar
I used the Trickflow chrome-moly pushrods. A wise investment.
Old Aug 21, 2010 | 10:37 PM
wrd1972's Avatar
Comp Hi-tech.
Old Aug 26, 2010 | 04:05 AM
Rob94hawk's Avatar
I hope these are hardened because I just ordered them yesterday and it doesn't say they are hardened anywhere. I'll look them up on trickflows website.
Old Aug 26, 2010 | 07:35 AM
bw_hunter's Avatar
You're going to change the oil, right? That metal had to go somewhere....
8T8IROC
Mar 26, 2015 09:02 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
TitoPR221
Jan 29, 2015 08:00 PM
Catmaigne
Dec 25, 2014 12:16 PM
Hurin
Dec 13, 2014 07:38 PM
