guide plates
Old Jan 28, 2007 | 05:35 PM
riodealz28's Avatar
guide plates
are thes guide plates good or do u all recommend something else
http://www.tpis.com/index.php?module...y=Guide+Plates
Old Jan 28, 2007 | 07:50 PM
seawolf06's Avatar
Those look like the comp cams guideplates which won't work on our heads. Get the Isky adjustables or GMPP ones.
Old Jan 28, 2007 | 07:51 PM
GM plates 14011051 or adjustable is all I would consider. Those look to fit regular SBC engines and the the spacing for the pushrods on the LT1 is not identical.
Old Jan 29, 2007 | 02:50 PM
riodealz28's Avatar
thanks
Old Jan 29, 2007 | 03:02 PM
SS MPSTR's Avatar
I have a set of GM's for sale. PM me if interested.
Old Jan 29, 2007 | 03:04 PM
arcticz28the383's Avatar
I also suggest the GM ones, theyre cheap and work well.
Old Jan 29, 2007 | 03:38 PM
Klaus's Avatar
You might want to read this:
http://web.camaross.com/forums/showthread.php?t=460413
Old Jan 29, 2007 | 04:37 PM
There are conflicting views in that post anyway, and guideplates wear based on other factors too. Pushrod length, quality of the pushrods, making sure your studs are tight, and things like these have an impact. I have 4500 miles on my GM guideplates with no wear. I am using comp hardened pushrods and made sure the rocker was centered on the stem. Overrevving and putting a slight bend to some pushrods will also cause guideplate wear and will also increase the harmonics of the valvetrain at high rpm.
Old Jan 29, 2007 | 05:21 PM
Klaus's Avatar
All true, but keep in mind that GMPP has a history of not hardening some of their parts properly. Do a search on GMPP LT4 ED timing gear teeth!
http://web.camaross.com/forums/showthread.php?t=278981
http://forums.corvetteforum.com/show....php?t=1251482
Ericksd
Jan 20, 2016 06:07 PM
NewsBot
Sep 30, 2015 04:20 PM
95blkss
Sep 22, 2015 03:18 PM
NewsBot
Sep 14, 2015 09:20 AM
Aaront810
Sep 11, 2015 11:24 AM
