Guestion about balancing my engine
ive got a 94 z28 just had the engine rebuild. it now has srp 2 valve relief pistons that are 30 over and eagle i beam rods with total seal rings. and the crank turned 20/20. ok heres the question ...the machine shop that done the work dint balace my motor ..they said i dint tell them to ..do i need to be worried about if messing up or should my parts that i used for the rebuild be close to stock balance ? the motor has a cc306 cam and c/r of about 11.5 or more .... its not a race car but i do want to run it hard when i need to take out that mustang thats talkin **** ...lol...it will (maybe if the engines ok) see nitrous...thanks
ya i agree 100 % but its already in and its running very strong for now , its took me almost a year to get this thing going i dont have the time or money to have it redone ....ticking time bomb ...just my luck
I cannot believe that the shop did not inform you that balancing was necessary when changing all those components. Sounds like some cob-it-together hack shop that you should never go back to.
if it has a noticeable vibration, a balancer isnt gonna help..
you really need to tear it apart and get the crankshaft balanced..
an unbalanced engine puts a lot of unneeded force on bearings.. not to mention it can prematurely wear about every component in an engine...
stockssn2o
May 25, 2015 08:54 AM
