guess what it blew again
Old Aug 29, 2006 | 02:58 PM
  #16
1racerdude's Avatar
Re: guess what it blew again
How much is it bored?
Has anything happened to the block to make ya think it is/would be a crack?
Look for a crack going around the top 1/2" of the cyl. If ya see something and are not sure take a propane bottle and heat it up SLOWLY to see if it opens up. Just let the end of the flame touch the metal and don't get it hot enough to change coolers.
Is there water getting into the cyls? Water leaking to the outside?
Water marks on the gasket from running that short of time would not be seen unless ya have dye in it.
Old Sep 3, 2006 | 07:08 PM
  #17
TransAmGT94's Avatar
4.060 bore coolant in cyl. during the second attempt it was leaking water from the spark plug hole in cyl 4
Old Sep 3, 2006 | 08:51 PM
  #18
Robs97Z28's Avatar
did you use apr thread sealant on all of the bolts? or did you use something different? when my head blew it was leaking around the bolts.
Old Sep 4, 2006 | 08:50 PM
  #19
used the tape for sealant
Old Sep 4, 2006 | 09:10 PM
  #20
Robs97Z28's Avatar
I would use the apr thread sealant next time.. it is cheap and easy to use. when you pull it apart look at the head gasket around the head bolt, you should be able to see small white lines around the bolt holes. ARP-100-9904
I bet this will fix your leak.
http://store.summitracing.com/egnsea...115+4294844684
Old Sep 5, 2006 | 12:06 AM
  #21
1racerdude's Avatar
The tape is OK. Two different ways to apply the same material.Just a bit quicker to use the goooooo.
Never was into flat rating race engines.
Old Sep 12, 2006 | 08:21 PM
  #22
final answer is there are cracks in the head bolt holes causing coolant to leak... Kinda thought that would be something that they should have noticed. now my options are toss it and start over on a new block or go back to the original motor.
Old Sep 12, 2006 | 09:49 PM
  #23
Robs97Z28's Avatar
that fing sucks, good luck
Old Sep 13, 2006 | 03:45 AM
  #24
oneslowz28's Avatar
Who makes the heads?
Old Sep 15, 2006 | 09:09 PM
  #25
not the heads fault its on the block end
Old Sep 15, 2006 | 11:30 PM
  #26
1BigBird3's Avatar
Keep the faith brotha.
Best of luck and keep us posted!
Ruben F.
Old Sep 17, 2006 | 06:11 PM
  #27
mebanditws6's Avatar
I talked to Chris (TransAMGT94), and the latest is that the shop is looking for another LT1 block to start on. It's either that or use the OEM block which is still at stock bore. Once that is established, they said they will talk. They did say that he shouldn't have to pay for "some" of the buildup again, that is if Chris decides to use them again with a different block.
Whatever that means I haven't a clue. If it were me, I'd make the shop give me an estimate in writing before making another step towards building another block. They've had the whole motor for over a week and have supposedly torn it all down.
Jason
Old Sep 25, 2006 | 09:43 PM
  #28
Looking for a block right now shop says if i produce a block they will machine and put it back together for free.... any body have a lead on a good 2 bolt or 4 bolt block let me know
Old Sep 25, 2006 | 09:50 PM
  #29
Loadre's Avatar
.060 over is pushing it without a sonic check.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
