How to prime oil on lt1 ?
Old Sep 25, 2006 | 06:48 PM
zoelt1 94's Avatar
I just had my LT1 motor rebuilt, and was wondering how do I prime the oil in the motor or do I have to at all.
355 lt1
11:2 compression
compcam # 07-503-8 @.050 224 230 .503 .510
stock lt1 heads mild port
forge piston and crank
6.00" I-beam rods
also could I use the stock injectors with this setup, or should I purchase a new set, and if I need a new set pls post spec.
The finale question will I have to worry about detonation on 92 octane fuel or will the tuning help with that
Old Sep 25, 2006 | 07:27 PM
zjet's Avatar
Re: How to prime oil on lt1 ?
If the intake is on it,you just have to install it and crank it with the coil wire off to build oil pressure.
If the intake is off,pull the cam drive that turns the oil pump shaft and use a drill and a primer rod and spin the oil pump with the drill.
You could use stock size injectors (24 pd) with it but unless it's a low miles set up.I would change them.28 or 30 pd injectors would be good upgrades.
Old Sep 25, 2006 | 09:11 PM
razor02097's Avatar
if your engine builder used actual assembly lube you would be ok just to start it. If not its best to prime it without cranking the engine.
Old Sep 25, 2006 | 09:53 PM
zjet's Avatar
I didn't even think about the assembly lube.Good catch.If it hasn't been to long since assembly the cylinder should have enough oil in them to crank it a few times,but its best to prime it first,even if having to pull the intake
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
