Grounds on 95 LT1
Old Jul 17, 2003 | 11:01 AM
HardcoreRM125's Avatar
Grounds on 95 LT1
Where are all the grounds at for a 95 LT1 ?
Old Jul 17, 2003 | 11:11 AM
PatriotTA's Avatar
I'm sure Shoebox will know. But there's two in front on the engine bay, in front of the radiator, on either side. Little black wires bolted down. Also that red box on the passenger side strut tower. There are some in the hatch too, I can't remember if its behind the tailights or in the behind those removable speaker panels. Maybe both. HTH
Old Jul 19, 2003 | 08:10 PM
TTT Any others ???
Old Jul 19, 2003 | 11:15 PM
carlos64030's Avatar
If I'm not mistaken, I believe there is 1 on the front of the engine block on the driver's side.
Old Jul 19, 2003 | 11:23 PM
There are ~13 different main ground locations all over the car. What is it you are after?
Old Jul 20, 2003 | 08:48 PM
Basically i need all the ones that are udner the hood area of the car. I bought a Z without the engine in it, cuz the frame was messed. Am almost ready to start it up and need to make sure i got all the grounds ... So where are the ones at on the front of the vehicle? In the Dash ? I dont need any of the other ones ... Thanks
Old Jul 20, 2003 | 09:44 PM
RH side of engine block by the motor mount-battery cable ground.
LH shock tower (seen in upper part of left pic) next to the red plastic 12v junction-3 rings, 5 wires.
LH front of head where the coil bolts on-3 rings, 3 wires and braided ground strap.
RH side of engine block above the starter.
One on each side of the radiator on the top of the radiator support.
Left front frame rail by the cruise control. Braided ground strap (to coil stud) and ground for cruise control.
Under LH (right above the hood release and hidden by my label) and RH (just barely visible in the top right of the pic) kick panels is a large ground lug.
Old Jul 20, 2003 | 10:13 PM
thanks
Old Jul 20, 2003 | 10:24 PM
Shoe Box , i got em all except for the 3 on top of the strut tower on the passanger side , i only have 2 loops not 3 , the 2 i have come off the main bundle of wires running along that side of the endinge bay , where does the 3rd one come from ? Like what part of the harness ?
Old Jul 21, 2003 | 06:10 AM
Mtrhds94Z's Avatar
MAke sure you realize these are 'HOT'... 'not grounds'..
As shoebox said it's the stud just to the rear of the 'red box' that are grounds..
THe '3rd' ground on the psgr side shock tower stud comes from the negative battery cable..
Old Jul 21, 2003 | 09:03 AM
I knew they were hot, but thanks and i guess that explains why i didnt hook the 3rd up because i neither have a battery nor do i have all those lines organized , jsut a mess of wires still , ill do them today, see if i can get it ready to start , then tommorow try and fire it up ...
Old Jul 21, 2003 | 09:35 AM
Like Charlie said, there is one big one that goes to the negative side of the battery. The two rings you have, should have two wires each on them.
Old Mar 12, 2023 | 02:32 PM
plumz's Avatar
Re: Grounds on 95 LT1
Sorry for reviving such an old thread but i an desperate. I am having issues with my lights and the general consensus is that it is a ground. I need to locate ALL grounds and am having trouble hunting them all down. Shoebox seems to know where they all are but the links to the pics no longer work. Please assist, NEW member in desperation!!! Thanks
Old Mar 12, 2023 | 03:04 PM
The grounds are all shown in the factory service manual. See section 8A - Electrical. What is the year and model of your car? There can be slight differences between the Camaro and Firebird, and from year-to-year.
Download the correct manual (free) here:
https://www.mediafire.com/?40mfgeoe4ctti
Shoebox has the schematic for the 1995 Camaro lighting. Grounds are identified starting with the letter “G”. For example “G106” for part of the headlight system. The factory manual has a list of grounds in each system, and tells you where they are located.
http://shbox.com/1/headlight_chevy_1995.jpg
http://shbox.com/1/exterior_lights.htm
http://shbox.com/1/interior_lights_1995.jpg
Old Mar 12, 2023 | 03:44 PM
plumz's Avatar
Thanks for your reply. I started reading the service manual however it says that it is book 1 of 2 and 8a is in book 2. Am I missing something, is the second manual in the download list. Sorry if I missed it, sometimes my head is where the sun don't shine.
