Grounds on 95 LT1
Old Mar 12, 2023 | 03:55 PM
  #16
plumz's Avatar
Re: Grounds on 95 LT1
I found it...I'm an idiot
Old Mar 12, 2023 | 04:37 PM
  #17
plumz's Avatar
so here is what is going on.interior lights stay on and will not shut off (mirror and dome). It does this intermittently but mostly on, they flicker or shut off sometimes when the cam shakes the car or I slam the car door. When i press the brake, he courtesy bell chimes and the dash light illuminate. When I use the left turn signal it works correctly, when using the right signal it turns on the hazards. Headlights, running lights, brake lights all work correctly. I have changed he pin switches, cleaned up all the grounds in the engine compartment and the one for the tail lights in the rear. I have tried several flashers, replaced ALL bulbs. Also at one time the passenger front turn signal would BARELY illuminate. Any ideas? Thanks for your help!
Old Mar 12, 2023 | 05:16 PM
  #18
plumz's Avatar
The index on the service manual says that all interior and exterior lighting is in 8b. The manual goes from 8A to 8C. the way things are going I should have expected something like that!
Old Mar 12, 2023 | 05:39 PM
  #19
I’ll try asking this one more time - see first paragraph of my post #14 above.
WHAT YEAR AND MODEL IS YOUR CAR?
The factory service manuals are organized differently from year to year.
Old Mar 12, 2023 | 05:42 PM
  #20
plumz's Avatar
I'm sorry, it is a 1995 z28
Old Mar 12, 2023 | 06:52 PM
  #21
plumz's Avatar
Ok sir, I found it. It shows all of the different components that are grounded to a particular ground source but I do not know WHERE those ground points are located in the vehicle.
Old Mar 12, 2023 | 07:03 PM
  #22
There should be a table/list, located after the schematic that lists every component (sensors, harness connectors , splices, grounds, etc.) on the diagram, where it's located in the vehicle, and an index to the 8A-200 section page and diagram # that shows the location (for most components).
Cmr0z28
Nov 20, 2006 10:49 AM
ghost stripes
Apr 19, 2006 04:17 AM
TMoNeE98
Mar 23, 2006 10:16 AM
Z28sky
Parts Wanted
Mar 7, 2006 08:39 PM
SMOKINGV6
Jan 9, 2005 01:01 AM
