grounding problem?
Old Mar 31, 2004 | 04:17 PM
CrAkD X 95TA's Avatar
grounding problem?
ok the car will start up if the coil is not mounted but if its mounted it wont start and it makes some kind of backfire noise from the throttle body any ideas?
Old Mar 31, 2004 | 04:37 PM
valter's Avatar
I think it's quite possible coil itself got grounded. Make shure that it's not a wires to it - they can also loose connection / became grounded depending of their position...
Old Mar 31, 2004 | 04:39 PM
Pretty weird. Not even sure how you were able to figure out unmounting the coil would make it run.
Is it just unmounting the coil or the coil and ICM together? Sounds like there might be a short to ground in one of those components.
Old Mar 31, 2004 | 04:40 PM
well the wire going from the coil to the opti is all corroded from the old coil....i cant buy a new one without buying a whole kit of wires cause when i got my tune up they never changed the coil wire...think that would do it?
Old Mar 31, 2004 | 04:42 PM
well i replaced the coil cause the old one was corroded so when it didnt start we just plugged in the old coil without unmounting the new one and it started right up. so then we mounted the old one again and again it wouldnt start. the whole thing when we took it off we took of the plate behind it as well is that the ICM?
Old Mar 31, 2004 | 04:53 PM
So did the old coil work when it was mounted?
You can buy just the coil wire from the dealer or an AC-Delco supplier, but it won't be cheap.
I am not sure if the coil wire could be an issue, but my mindset is that if I see something that looks like it could be a problem, I eliminate it as a factor.
Old Mar 31, 2004 | 04:54 PM
no it didnt i didnt get to try the new coil unmounted
Old Mar 31, 2004 | 04:55 PM
my buddy seems to think the "sucking" sound coming from the throttle body is the timing....think the timing could have been set out of wack somehow well he was doing the waterpump?
Old Mar 31, 2004 | 04:58 PM
You can't alter the timing by changing the water pump. Now, if the optispark got soaked with coolant, that could make it run funny. However it would not clear up by unmounting the coil.
Old Mar 31, 2004 | 05:00 PM
well we dont know if it ran funny it just started and we cut it off cause the radiator cap was off and everything was apart.....i couldnt afford to replace the opti at the time but it looks like im going to have to replace it if i cant get this fixed.
Critter
Jul 7, 2015 08:33 PM
eanhl2004
Apr 4, 2015 12:01 PM
BigWil
Mar 29, 2015 12:24 PM
blac94Z
Mar 20, 2015 09:58 PM
JSK333
Sep 9, 2002 10:33 PM
