Grease for hood latch assembly
Re: Grease for hood latch assembly
Originally posted by $hawn
Should the moving parts on the hood latch assembly be greased up, or is it not really needed, if so just grease any part that moves right?
Use some chassis grease that should do it. Just don't go overboard. Do you have a squeak or something? If you do, it may be better to adjust the rubber/plastic stoppers under the hood. That will create more tension when closed and may solve a squeak.... (If you have one that is)
alliance12364
Sep 17, 2015 08:43 AM
Toxintwins
Sep 11, 2015 11:13 AM
