Grease for hood latch assembly
Old Jul 12, 2003 | 11:00 PM
$hawn's Avatar
Should the moving parts on the hood latch assembly be greased up, or is it not really needed, if so just grease any part that moves right?
Old Jul 13, 2003 | 08:47 AM
scoobysnax83's Avatar
Re: Grease for hood latch assembly
sounds good to me... Use some chassis grease that should do it. Just don't go overboard. Do you have a squeak or something? If you do, it may be better to adjust the rubber/plastic stoppers under the hood. That will create more tension when closed and may solve a squeak.... (If you have one that is)
Old Jul 13, 2003 | 01:25 PM
$hawn's Avatar
Naw, no squeek or anything, me being a neat freak noticed that it was grimmy and decided to clean it up, so I figured I would put some grease on the moving parts or something.
Old Jul 13, 2003 | 04:53 PM
yep good idea.
I'm the same way.
Z Power
Sep 19, 2015 11:19 PM
alliance12364
Sep 17, 2015 08:43 AM
gearhead3
Parts Wanted
Sep 16, 2015 08:18 AM
Toxintwins
Sep 11, 2015 11:13 AM
Daluchman1974
Sep 11, 2015 06:12 AM
