Granatelli MAF Garbage?
Old Aug 27, 2010 | 04:24 PM
97softopZ's Avatar
Does anyone have anything positive to say about the Granatelli MAFs? or any aftermarket MAF?
Old Aug 27, 2010 | 05:59 PM
ray396's Avatar
Cool
Hi, I just removed the screen from my stock one, and cleaned it, put it in and i noticed the throttle response was better, and ran smoother. Just letting you what worked for me.Ray
Old Aug 27, 2010 | 06:47 PM
Those would probably be in the minority. MAF descreening is also a sore subject with a lot of people. Most tuners like a non-molested stock MAF for tuning purposes, because it has reliable/predictable output.
As I recall, MAFs that claim HP gains have a spotty record and I think most came out before the onset of readily available computer programming (IMHO is the better way to accomplish changes).
Old Aug 28, 2010 | 12:40 PM
97softopZ's Avatar
IMHO?? Not too tech educated. laymans terms?
GRIDERMAN87's Avatar
In my honest opinion
Old Aug 28, 2010 | 03:04 PM
97softopZ's Avatar
haha
Old Aug 28, 2010 | 06:26 PM
Kevin Blown 95 TA's Avatar
Mine worked since the day I got it back in 99 or whenever it was and I only bought it because it was bigger than stock and I wanted a bigger inlet for the blower because it was on the suck side. I doubt it would have made more power in a NA engine and I think that's a bad reason to buy one. I interchanged it with the screened stock one a bunch of times since then to see if idle quality and normal driving was affected and I couldn't tell a difference - BLMs and all that stuff seemed the same as well. So it isn't garbage but I don't know if it would benefit a NA engine - mods like that and the IAT relocation aren't a good way to get power if someone is hoping for a recalibration to leaner mixture and more grunt in the LT1 fat spot. A good tune will usually get you there.
Old Aug 28, 2010 | 09:48 PM
96capricemgr's Avatar
The Granatelli might result in more power by missreporting airflow to trick the pcm into leaning out overly rich factory wide open throttle tuning. You could pay $300+ for a hit and miss MAF or you could spend half that, get the fueling corrected, the spark optomized so on and soforth. Really a poor idea.
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
