MAF cleaning, need sugestions!
Old Aug 28, 2010 | 03:13 PM
camz28ryan's Avatar
i took the MAF sensor off and sprayed it with MAF sensor cleaner, and let it dry, then put it back on, when i went i started it, it died right away, so i started it it again and it was fine, then about an hour later it went to start it and it wouldnt start for about 10 secs of turning it over, then it started back up again, why is it doing this?
Old Aug 28, 2010 | 05:41 PM
maddog05's Avatar
When you reassembled the MAF area ther was an error of some type...Check for vacuum leaks, a lose wire connection or allignment eproblems. The cleaner MAF could not cause these symptoms. As maddening as this may seem take ypour time and work on it in a well lighted area.
Old Aug 29, 2010 | 04:05 AM
brucer's Avatar
did you put the maf back in the correct direction?
95blkss
Parts Wanted
Jul 19, 2015 08:42 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Noct
Jul 14, 2015 01:18 AM
