Got some Dynatech lts now what??
Old Oct 22, 2003 | 02:11 PM
bradpreece95z28's Avatar
What kind of set up should I run from the headers back?
i have a borla exhaust on there now, but I am not against pulling it off and running dumps.
I am open to suggestions for this setup.
Please help me with this guys, also, please give me some web links for the parts to order. thanks a bunch!!!!!
Old Oct 22, 2003 | 02:24 PM
jonaddis84's Avatar
Just weld some dumps onto some collectors and bolt them onto the header collectors
Old Oct 22, 2003 | 02:26 PM
Camaro_Maniac63's Avatar
Leave that Borla on there, and if you want louder, go get yourself a cutout. With the cutout, you get the same (if not better) gains compared to true duals, and for much less money. Just my opinion. Good luck.
Old Oct 22, 2003 | 02:30 PM
Not a bad idea
I just do not know what to do, I am wanting to do something that is not that radical, like dumping, but then again, I like em loud
Can someone point me in the direction of the collectors/y pipe needed for the dynatechs? Please?
Old Oct 22, 2003 | 02:33 PM
jonaddis84's Avatar
Man i was just screwin around, you wouldnt be able to see anything your eyes would be shaking, you have to weld some collectors (just the universal 3-bolt flanged collectors) onto some 2.5" or 3" pipe, then into some dynomax bullet mufflers, then into dumps before the axles, if you take it to a muffler shop they will know what to do.
Old Oct 22, 2003 | 02:36 PM
So, basically, some flanged 3 inch collectors, some 3 inch bullets and some stainless spipe and I should be in good shape?
Old Oct 22, 2003 | 02:42 PM
jonaddis84's Avatar
Exactly, dont forget the dumps. If you want to spend a little more and less interior noise, you can have them bend it over the axles out the back.
Old Oct 22, 2003 | 02:44 PM
FacelessZ's Avatar
go with a custom 3" Y for the Dynatech's...$90-$100 installed...
Old Oct 22, 2003 | 02:45 PM
FacelessZ's Avatar
then just install 2 cutouts, one after each header...and you'll be set
maybe2fast
Mar 16, 2015 11:59 AM
BadBwty
Feb 18, 2003 05:26 PM
myricekiller
Feb 10, 2003 08:44 PM
Fusion93Z
Jul 13, 2002 01:02 PM
CW 99 Z
Jun 24, 2002 06:15 AM
