Got some codes today -HELP PLEASE (shoebox)
Old May 31, 2004 | 04:35 PM
OnefstCamaroZ28's Avatar
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
Alright I got:
PO175
PO300
P1641
P0753
Shoebox, or anyone else who knows their stuff, can you help me out. Like what should I check, replace or test. Any help would be great!
Thanks so much
Old May 31, 2004 | 05:07 PM
PO175: Fuel System Rich Bank 2
PO300- Engine Misfire Detected
PO753: 1 - 2 shift solenoid - electrical
P1641: Fan Control (FC) relay 1 control circuit
Old May 31, 2004 | 05:22 PM
I did install a manual fan switch so maybe thats why P1641 codes it going off.
Any help?
Old May 31, 2004 | 06:46 PM
The first two could be related, in that a misfire might help cause a rich indication. Check plugs and wires.
The fan code could be caused by your fan switch, depending on what method you used to install one. You might want to follow some recommendations on the schematic, here.
You would probably feel harsh shifts if your 1-2 solenoid was having a problem. Might have been an intermittent thing as well. Clearing the code and seeing if it comes back might be in order.
Old Jun 1, 2004 | 08:40 AM
Thanks a lot! I installed the fan switch by splicing into the fan control relay. Yes my 1-2 shift is really harsh, but I have a shift kit so thats why i always thought it was just the shift kit. Do does this mean my solenoid is messed up and i need to rebuild my tranny?
Apr 3, 2015 10:54 AM
30thZ4C
Dec 26, 2014 05:09 PM
StngStlkr
Sep 6, 2002 05:47 PM
91Bird305
Aug 5, 2002 01:39 PM
Nick's WS6
Jul 25, 2002 04:20 PM
