Got a quote on header install and camswap
Old Dec 7, 2007 | 04:07 PM
a4z28's Avatar
I got a quote today to do a header swap with the ory and cutout plus a camswap and valve spring change for 1100 this is for labor only . I will supply them with gaskets and all parts needed. Do you think this is a fair price they do alot of impala ss lt1 motors so they know what they are doing. What do you guys think. If it wasnt so cold i would do it myself but my workspace is limited to the driveway. Cause my 69nova with a 434 sbc pumpgas car is in the garage until the spring.
Old Dec 7, 2007 | 04:12 PM
thebufenator's Avatar
I think that sounds really good actually.
Is it just a cam swap, or cam + rockers?
Old Dec 7, 2007 | 04:16 PM
a4z28's Avatar
It is with installing cam, springs,locks,retainers,shims,timingchain,rockers guideplates and studs. Basically everything needed to get the job done right.
Old Dec 7, 2007 | 04:21 PM
n2ceptor's Avatar
That sounds about right...... Talking with some of the shops where I live, it would cost around 500~700 dollars for just headers/exhaust installed.......
Old Dec 7, 2007 | 04:59 PM
maybe2fast's Avatar
good deal, or just do it yourself and save a G
Old Dec 7, 2007 | 05:09 PM
2QUIK6's Avatar
I agree, $1100 is a good deal provided they know LT1s and it sounds like they do.
Old Dec 7, 2007 | 08:24 PM
raroz28's Avatar
that's not a bad price, but it's just a quote. I'm sure the bill will be a lot bigger when you go to pick it up.
Just keep in mind that a cam swap in this car is about as easy as it gets.
Old Dec 8, 2007 | 06:14 AM
The Engineer's Avatar
What part of the country are you from? Labor prices vary a lot from one area to another.
WD
Old Dec 8, 2007 | 08:08 AM
a4z28's Avatar
I am from NY and the guy told me that it wouldnt cost know more than 1100 cause he said to do headers is 400 - 500 and cam swap ranges 400 to 600 on these cars he defently knows lt1 cause he did work on my freinds 383 lt1 ss impala and did it right.
Old Dec 8, 2007 | 08:49 AM
Dave1980's Avatar
If you did the work yourself you could put down a little more and have heads to go with it!
Old Dec 8, 2007 | 02:49 PM
rob97ss's Avatar
Where in NY? Which place?
Old Dec 8, 2007 | 06:03 PM
QICSAN's Avatar
That's about right on the low end, great price. I charged $1600 for the same plus programming for the mods, so it's about same as I charge. The plus would be it's an experienced LT1 shop(that makes a different).
LJ
Old Dec 8, 2007 | 07:12 PM
Jazsun's Avatar
As easy as it gets? Are you sure about that?....what about the ls1
Old Dec 8, 2007 | 07:22 PM
raroz28's Avatar
pull valve covers, intake, pushrods, front timing cover and you're pretty much done.
U gotta move a lotta stuff outta the way but it's still extremely easy.
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
