Got my car dynoed today
Not bad but the AFR is way lean over 5,000 rpm I havent had time to check fuel presure but I beleve its the programing
by 5,800 the AFR is 14.5 and is 14.0 or higher from 4,600 on up
even with the 14.5 AFR the car dynoed at 312 at the wheels at around 5,500
on the graff you can see the HP curve start geting chopy once the AFR got leaner than 13.5. I was predicting 330 to the wheels so it came up a little short, but if the AFR was proper maybe it would have made more.
Re: Got my car dynoed today
dude what happened, my formula dyno'd 268RWHP stock, after pocket porting the heads and 58mm TB with CC306, heh, big dirrence, it was like i didn't even need my 175 shot anymore. wtf?
Dmoor88- As said in my sig most all parts on my car are edelbrock, I have the heads, cam, headers, and exhaust also a Cat from RK sport that is suposed to be high flow but dosent look it. I also have 24lb accell fuel injectors because the originals got stuck from sitting for over 4 years.
the first dyno pull the oporator shut the car down at only 4,900! were the car made 297 at the wheels! so it is making more power a stock LT1 at power peak.
I'm going to make sure the fuel pressure is not droping off before I go ahead and send the chip back.
ChrisFrez
Dec 28, 2014 02:25 PM
ChrisFrez
Dec 21, 2014 09:47 PM
