Got a dash light that came on today
Old Sep 17, 2003 | 11:21 PM
  #16
95zChic's Avatar
The low traction light comes on the left side of your panel I believe at the bottom and it says Low Trac
Old Sep 17, 2003 | 11:34 PM
  #17
SiDeWaYZz28's Avatar
it is the low coolant light mine just turned on yesterday and my coolant was hella low im bout to flush it and put new stuff in tommorow night . .i was pissed when i seen that light because that meens more work for me . . im aready changing my pinoin seal tommorow too damm rear end is leaking
Old Sep 17, 2003 | 11:40 PM
  #18
95_RipperZ's Avatar
Well turns out the coolant is low. I cant even see any in there. Now what?
Old Sep 17, 2003 | 11:42 PM
  #19
notstock4long's Avatar
See any in where? Check the reservoir dip stick. Just fill the sumbitch up and see what happens. See if it gets low again.
btw, fill from the radiator.
Old Sep 17, 2003 | 11:45 PM
  #20
95_RipperZ's Avatar
Should I check the oil first to make sure I am not running it with a head gasket blown?
Old Sep 17, 2003 | 11:48 PM
  #21
No, don;t get ahead of yourself yet. Start the car, the nfill the radiator until it gets to the top. Then when the level drops, add some more, do this until it stops dropping. Also, check the coolant dipstick on the reservoir cap.
Old Sep 18, 2003 | 07:35 AM
  #22
If you even remotely think you might have a head gasket problem, then heck, yeah, I would check the oil first. The more you run it with water in the oil, the more damage you will do to the bearings.
Old Sep 18, 2003 | 10:41 AM
  #23
95zChic's Avatar
Then your water pump is probably leaking. Unless your right and you've got a blown gasket. The water pumps are pretty expensive and a complete pain to try and change I had to change my about 6 weeks ago. And I took mine to the pros b/c there was no way that I could do it by myself..
Old Sep 18, 2003 | 11:38 AM
  #24
if u cant see coolant well obvisoly you r low on colant and if u blew a head gasket u would see white smoke out the exhaust
Old Sep 18, 2003 | 12:06 PM
  #25
95_RipperZ's Avatar
Well I had a good suggestion in my other thread that the radiator cap could not be keeping pressure. It is kinda raggedy and broke. $5 fix if that is it.
I don't see any smoke coming out of the exhaust and there are also no leaks of coolant anywhere. Kinda easy to smell. I have a small oil leak from somewhere on the timing cover but that is it. How can you tell if you have coolant in the oil? Should it be obvious? How bad would the white smoke coming from the exhasut be. Would I be able to see it?
I have a CSI waterpump on there now, 2 months old. I'll check that too today when I get home to make sure it is still working properly.
The last thing I need now is a spun bearing. A new engine would be nice if I had the money though.
Old Sep 18, 2003 | 01:06 PM
  #26
if u blew a head gasket there would be clouds of really white smoke
Old Sep 18, 2003 | 02:13 PM
  #27
Jason Dove's Avatar
I blew my gasket it would take about 2 weeks to burn enough water for the light to come on... so I couldn't see any steam in the exhaust until it was bad enough to take 3 days to turn on the low coolant light.
Old Sep 18, 2003 | 03:11 PM
  #28
95_RipperZ's Avatar
Did you have any damage to the bearings?
Old Sep 19, 2003 | 02:51 PM
  #29
Jason Dove's Avatar
Nope, I think the leak was slow enough that it was burning off all the fluid that came though. The oil looked completely normal. No foaming, nothing...
I wasn't getting a ton of steam, just enough to notice if I was looking for it (which I was since my water was disappearing).
Old Sep 19, 2003 | 02:57 PM
  #30
Terran2k's Avatar
just to re-affirm a prior post....when my radiator cap was not fuctioning properly I would have to fill my radiator every few days. I thought it was a head gaskey, but I popped a new cap in (just a regular Stant cap from autozone, for the curious) and its been good, I havent added any coolant since I popped the new cap on and its been a few months!
warmeck
Feb 5, 2015 11:04 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
fpete1992
Dec 11, 2014 03:51 PM
siguy
Nov 27, 2014 10:07 AM
StngStlkr
Sep 6, 2002 05:47 PM
