got a code today, RANDOM MISFIRE...
Old Nov 20, 2003 | 06:03 PM
steelheart's Avatar
hotcam has been in the car for a few days now, and i got a code for a random misfire, but the car is running fine and not misfireing at all, i do still have to get it tuned for the hotcam but i was thinking maybe its the crank sensor not reading something correctly, anyone have any ideas??
Old Nov 20, 2003 | 07:47 PM
steelheart's Avatar
anyone?
Old Nov 20, 2003 | 08:11 PM
chaotik169's Avatar
I had the same problem, my mechanic told me to get the idle raised a little bit and the problem went away, when it was cold out it ran rough and gave me the flashing SES, random multiple misfire, im checking my coil and opti now..
Old Nov 20, 2003 | 08:52 PM
CatsTasteGood's Avatar
Check to make sure all your plug wires are on tight. After that, if you can clear the codes, do it. If your ses comes back on, you know you have to check more, like spark plugs, rotor, etc...most likely its an ignition problem.
Old Nov 20, 2003 | 09:33 PM
steelheart's Avatar
its got brand new plugs, gm wires and a gm cap and rotor not a auto zone unit, and i know everything is on right, anyone think a crank sensor can cause a random misfire
Old Nov 20, 2003 | 09:35 PM
LSUxBlake's Avatar
If you just changed plugs and its throwing that code, chances are the plugs arent gapped right......
Old Nov 20, 2003 | 09:36 PM
LSUxBlake's Avatar
and no, dont think the crank sensor would cause it, as it has its own code to throw when its bad
Old Nov 20, 2003 | 09:58 PM
It never hurts to check the wires, the plugs towards the firewall can be a pain to get on there snug and can vibrate free during driving.
Old Nov 20, 2003 | 10:00 PM
JDBlaze85's Avatar
the optisparks internal cam sensor would be the one to report a misfire code. but with that cam, i wouldnt be surprised if that code would pop up. the pcm is sensitive to little bumps in the engine and is ready to throw that code out, more likely at a rough idle(like an aftermarket cam would provide). program your pcm for that cam first. it should help.
captcorvette
Mar 7, 2015 12:37 PM
nophix
Nov 30, 2014 10:26 PM
StngStlkr
Sep 6, 2002 05:47 PM
91Bird305
Aug 5, 2002 01:39 PM
Nick's WS6
Jul 25, 2002 04:20 PM
