Good valve springs for 1.6 and CC305?
Old Apr 26, 2004 | 07:33 PM
TransAm9585's Avatar
Im getting a set of magnum 1.6 self aligning RR and a CC305 im curious as to what valve springs would work best with this? Would the LT4 Springs work ok? And what else should i change while doing this? This will be run on my 95 TA. Thanks for any information.
Old Apr 27, 2004 | 06:15 AM
ttt
Old Apr 27, 2004 | 04:26 PM
Okay nobody has any ideas, im batting zero folks any help lol.
Old Apr 27, 2004 | 04:28 PM
LT4383's Avatar
I used the LT4 heads with no changes to valves or springs, with my old cc305
Old Apr 27, 2004 | 06:32 PM
brandboZ28's Avatar
I used the EX-612 springs from www.cmotorsports.com and they worked great.
Old Apr 27, 2004 | 06:37 PM
SS MPSTR's Avatar
Call Thunder Racing for the Isky spring they recommend for your application.
Old Apr 27, 2004 | 08:05 PM
12SCNDZ's Avatar
I know mine are Crane double springs, but I couldn't get an exact part # from my machinist. They're supposed to be good to .600" lift. I also know my COMP #986 springs wouldn't work.
Frank
Old Apr 27, 2004 | 08:13 PM
Would the LT4 hot cam springs work with this?
Old Apr 27, 2004 | 09:23 PM
SS MPSTR's Avatar
Do not use the LT4 springs. There are a few springs out there that will work, but only a couple that do not require machining of the spring seat within the head for an increased diameter. The Isky springs I referred to are the same as, or close to the stock diameter (1.240" I believe).
Old Apr 27, 2004 | 10:20 PM
97bowtie's Avatar
I ran the Crane 10308 dual coil valve springs for 2 years w/out any problem on my car with the CC305. The spring kit comes with locks, retainers, and shims. They are good to .600" lift and don't require any machining of the heads.
Old Apr 27, 2004 | 10:57 PM
snksknr94's Avatar
I'm running the Isky springs mentioned above.
Old Apr 27, 2004 | 11:22 PM
whatsup's Avatar
I'm installing the Cranes 10308 as we speak...look like a very good spring!!!
Old Apr 27, 2004 | 11:43 PM
truedualws6's Avatar
I bought the Isky 235-D springs for a Crane 210/224 cam
install. Have not put them in but I would think on a stock
head they would be fine with the CC305. Max lift with them
installed at 1.75 is .550".
I have since decided on a new plan to try the Comp
beehive springs. They are for the LSx motors but there
is a conversion retainer and lock that allows you to use
them with stock LTx heads. Part numbers are:
26915 or 26918 (depending on the pressure you want)
787-16 retainers
648-16 locks
The best prices I have seen are $139, $48 and $20
respectively. The Isky's are only about $85.
If the beehive springs sound interesting to you then
check out this post:
http://web.camaross.com/forums/showt...hreadid=253733
Old Apr 28, 2004 | 01:10 AM
97bowtie's Avatar
Glad you received the springs.
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
