New injectors with cam and heads?
Old Apr 26, 2004 | 10:54 AM
Eric85's Avatar
il be getting my heads ported with new valves (2.00/1.55) and also be getting a 233/239 cam to go with it. Ill have a walbro 255 LPH in tank but should i get new injectors also?
Old Apr 26, 2004 | 10:57 AM
LT4POWR's Avatar
yes
Old Apr 26, 2004 | 10:58 AM
simple's Avatar
Originally posted by LT4POWR
yes
what he said!
if you buy new, this is the cheapest place i have found SVO's www.gefracing.com
Old Apr 26, 2004 | 11:18 AM
Eric85's Avatar
SVO injectors?
Im confused.....
Old Apr 27, 2004 | 05:59 PM
disco192's Avatar
The SVO injectors are made by ford. The are 30 lbs rated at 39 psi. This makes them flow at 33.5 lbs at our 43.5 psi.
Old Apr 27, 2004 | 06:15 PM
RE AND CHERYL's Avatar
Thats an important piece of info. I'm ordering a set of these in a few weeks.
Old Apr 27, 2004 | 06:22 PM
thrift23's Avatar
What"s the difference in the matched injectors?
Old Apr 27, 2004 | 06:33 PM
IrocSS85's Avatar
matched means they have been tested and the set will all flow the same at a given press/duration.
Eric, I have the exact same setup as you, I got the SVO inj.s also. still not back together yet though. when is yours gonna be done? Im thinking mine will be done in a couple weeks, but Im not sure how quickly I will be able to get dynotime for the tune.
curious, whats the rest of your setup consist of? mines got 3:73 gears, 2800 stall, shiftkit, 52mm tbody, ported intake, DIYported heads, jethots/ORYP, and MSD. Im hopeing for at least 375 to the wheels. that'll depend on the heads I guess.
chris
Old Apr 28, 2004 | 02:03 AM
simple's Avatar
dont fret Eric, order up some SVO 30's
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
LT14LIFE
Feb 9, 2015 09:35 PM
skittlez87
Dec 29, 2014 03:23 PM
