good setup for not spinning?
Old Jun 26, 2003 | 11:18 AM
94droptopz's Avatar
whats the best shocks i should buy?i've heard a lot of good about the qa1 coilovers.
what about LCA's or what ever. im wanting my car to stick and get to the best of its abilities!!! thanks guys
Old Jun 26, 2003 | 01:38 PM
revtime's Avatar
Do you care if it takes corners well? If not, then I suggest an Eibach drag launch kit and a BMR adjustable torque arm.
Oh, and Nitto drag radials. Dial in 2 degrees negative at the track and it should hook real good.
QA1s are the best but if you are on a budget like me then KYB AGX is a nice budget alternative.
Old Jun 26, 2003 | 02:18 PM
94droptopz's Avatar
i dont want it to drive through the corners like a wet noodle but im not that worried about the handling. could i just replace the rear shocks for now and leave the worn out ones on the front?Or would it really help if i didnt change the front shocks? i know a little about motors but the suspension thing looses me. thanks for the help.
Old Jun 26, 2003 | 07:41 PM
revtime's Avatar
It won,t hurt anything to do the rears now and fronts later but you won,t get the full effect of the new shocks until all the new ones are on. I went full drag race on my suspension cause I got tired of people beating me while I played sit and spin.
I put in the drag launch kit and all poly bushings, the KYB AGX adjustable shocks, BMR adjustable TA, Lakewood LCAs and panhard rod, 3.73s and a TA girdle.
I still need to put my tranny back in with the new stall and see how it hooks up. I think with all that hardware my traction problems should be solved. The handling thing is the only bad part you can,t do the things you used to be able to do with the car handling wise but it should be ok for regular driving.
Old Jun 26, 2003 | 07:51 PM
12SCNDZ's Avatar
I cut 1.73 60 ft. times with a stock suspension. M/T 26x10.5" ET Streets, and removed front sway bar. Stock springs, shocks, control arms, and torque arm.
Frank
Old Jun 26, 2003 | 07:56 PM
revtime's Avatar
That is amazing, I tried everything I could think of to get my car to hook and I never did better than a 2.15 60 ft.
Maybe I just can,t drive
that is why I am trying to idiot proof my suspension, just put my foot down and go.
Old Jun 26, 2003 | 08:02 PM
12SCNDZ's Avatar
What gear/tire/stall converter are you using? Yes the motor, and suspension in mine was stock, but the rest had a little work. Check out my web page for specifics. You'll get to see a stock suspension car showing daylight under the drivers side front wheel.
DirtyDaveW
Dec 1, 2016 05:37 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
