good mild cam and best place to buy?
Old Sep 30, 2008 | 11:43 PM
Maverick_997's Avatar
alright getting ready to do some internals, im just lookin for a mild cam really, something that can be easily into the 350whp range without much effort. had porting will be done as well.. i was lookin into the HC kit and was interested in buying cuz it came with the rr and other misc stuff, but i know their tough to get to that power without all necessary bolt ons. soooo what size cam do you guys recommend will give me some numbers like im pursuing?? also where might be the best place to buy it??
thanks in advance
jeremy
Old Sep 30, 2008 | 11:51 PM
Klypto's Avatar
not sure for lt1, but the equiv. to a thunder racing, 224/224-112 or 114 is a greta cam, drive i daily (ls1) and very easy to handle
Old Oct 1, 2008 | 06:03 AM
krillformula's Avatar
I have the LPE211/219. Drives like stock bit with more hp/tq and the power band is about 2-300 rpms longer than stock. Has a little tiny lope. Just enough to tell there is a cam in there, with idle at 800.
Old Oct 1, 2008 | 08:58 AM
slomarao's Avatar
Wink
CC503 which is a xe 224/230 on 112 or 114lsa. The 114 would be tamer and would drive a little better. But also would leave 5hp on the table so its one of the decisions you would have to make.
The 503 is really common, lots of guys have put down 340-360rwhp depending on supporting mods. I would say its a pretty safe bet.
Old Oct 1, 2008 | 09:05 AM
HardcoreRM125's Avatar
CC503
I have a custom grind. But I am running similar duration with a WAY tigheter LSA = more overlap = more power, at the cost of a narrower powerband. Also is significantly more lift than a CC503. But the point I am making here, is I gained maybe 10+ horsepower over a CC503, at the cost of losing some driveability ... It does have some cam surge, and it does get irritating to drive slow in parking lots. If I did it over, I would either go with a CC503 and have no issues, or go with a CC306 and sound like a top fuel car ...
Old Oct 1, 2008 | 11:52 AM
blue 79 Z/28's Avatar
www.advancedinduction.com they have several cam kits for stock longblock motors, either way custom is really the only way to go if you want the most for your money.
Old Oct 1, 2008 | 11:21 PM
Mtxz453's Avatar
yea my cam kit has a lopey idle but sounds stock and drives exactly like stock but with a crapload more power
Old Oct 2, 2008 | 12:11 AM
yeah been pretty interested in the 503, im guessin the stock springs arent going to old up for much power over stock . lt4 springs maybe?? any other suggestions to throw in with this cam??
just curious what kinda power are you putting down with your set up right now??
Old Oct 2, 2008 | 12:37 AM
SS RRR's Avatar
Good cam.
DirtyDaveW
Dec 1, 2016 05:37 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
blue89iroc
Jul 18, 2002 03:35 PM
