Good Engine Combo?
Old Aug 18, 2005 | 07:25 PM
vonmoldy's Avatar
Good Engine Combo?
So I have made some progress on what I want here it is let me know What you think? What will this run?
LE2 Heads/Cam
?LE ported manifold?
58mm TB
1 3/4 Headers
30Lb Inj.
3.73 Gears
2800-3200 Stall Converter
Trans Cooler
What kind of rockers/pushrods should I use?
Should I replace Lifters? What kind?
What gains would a Vortech Intake elbow and TPIS air foil show?
Old Aug 19, 2005 | 01:10 AM
blackztpi's Avatar
Re: Good Engine Combo?
setup looks good.
ROCKERS-comp cams pro mag 7/16 stud non self aligning with arp 7/16 studs. use gm guideplates as well.
PUSHRODS- about any good chromoly wil do you best. crane, trickflow, comp cams, etc. of course, get a legnth checked to determine your size.
LIFTERS- ask lloyd if you have him do the package. certain springs will make you run a lifter like a comp R. beehives springs, and some others will let you use a stock typ lifter.
VORTECH ELBOW AND AIR FOIL- not on the "need to have" list. most aftermarket throttle bodies will already have a built in air foil. i know my BBK/edelbrock does. the vortech elbow looks like, but not needed as far as gains. you wont see anything really. but if you would get an aftermarket elbow, i wouldn't buy anything metal. metal holds heat much more than plastic, heating your intake air slightly. plus it's a bitch to touch on accident when hot.
oldschool
Feb 9, 2016 09:21 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
92ragtop
Dec 27, 2014 01:56 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
