What is the opinion on Holley 255 FP???
Old Aug 17, 2005 | 05:32 PM
lookingformore's Avatar
What are the pros and cons between the Holley, Walbro, or Racetronix fuel pumps........how are the installs?.....Cost difference....?....performance difference...longevity...
Old Aug 18, 2005 | 03:15 AM
Racetronix's Avatar
Re: What is the opinion on Holley 255 FP???
All are based on Walbro pumps so QC is the same.
Racetronix is the only company to offer true F-LT1 solution.
Old Aug 18, 2005 | 03:19 AM
Racetronix's Avatar
The LT1 F-body cars have a pump that is inside a plastic fill-bucket. The fill-bucket's inlet and check-valve system in combination with the fuel pump are designed to draw fuel from the bottom of the tank via suction. This keeps the bucket full at all times and the pump fully immersed in fuel regardless of the tank level so that when the tank is low on gas and you are doing some hard cornering or acceleration the pump does not run dry and start aerating (air bubbles) the fuel. This happens as the fuel sloshes from side to side in the tank leaving the center low on fuel. The F-LT1 cars have minimal to no baffling in them. This can cause detonation and possible engine damage. The bucket also allows the car to operate with lower fuel levels in the tank due to its scavenging effect. The bucket can also effect motor cranking time as the priming time is reduced under certain conditions. The return line from the fuel pressure regulator is diverted back into the bucket via a filter sock inside so that the unused fuel also helps keep the bucket full at all times. Keeping the pump constantly immersed in gas within the bucket can extend the pump's life by not allowing it to be exposed to open air. Open air within the tank contains moisture and in time will cause the pump to rust / seize up especially if left to sit for long periods of time without the tank topped-up (i.e. winter storage). The Racetronix pump assembly is modified so that it will seal in the bucket’s rubber check-valve so that its function is retained. The Racetronix pump assembly is fitted with a factory style fuel tube not a rubber hose. This hose is important as when the fuel module is placed back in the tank it must pivot which can cause the rubber hose to kink. This fuel tube is much more resistant to the solvents in today’s gas and it will not crack, split, swell and collapse like a rubber hose. The standard Walbro kit comes with a short length of 50PSIA rated rubber hose. The Racetronix fuel module is equipped with a one-piece soldered wiring harness made from mil spec. 14 gauge Teflon/silver wire. (upgraded from the factory's 16 gauge unsoldered harness) This is the same type of wire used at the factory as Teflon is the most resistant to deterioration when exposed to gas. This harness has a Walbro connector at one end and GM pins at the other which fit directly inside the factory connector. Due to the age of the F-LT1 cars much of the in-tank connectors are black / corroded due to age. The Racetronix harness replaces all these questionable components. The standard Walbro kit comes with a plastic coated in-line wiring adapter. This adapter must plug into the existing questionable factory in-tank wiring thereby adding additional connections and length.
The Pumps
Walbro Fuel Pumps have set the industry standard in high-performance. Walbro pumps are QS9000 certified and are used as OE equipment in many production performance vehicles such as the C5 Corvette. Walbro's gerotor design is able to maintain high pressures while providing high volumes as well. This is done by squeezing the fuel out between two gears instead of pushing it like most factory vane pumps do. (i.e. factory C4 pump). This positive displacement design makes high-performance Walbro pumps small, light weight, quiet, efficient and reliable. The Racetronix F-LT1 fuel pump assembly uses a 255L/Hr @ 43.5PSI @ 13.5V (300KPa) rated fuel pump.
Old Aug 18, 2005 | 09:27 AM
96capricemgr's Avatar
The upgrades connection tube is a nice touch, a friend used the rubber hose when he put in his Walbro and 2 years later was dropping it to replace it because it had split.
Old Aug 18, 2005 | 04:38 PM
OK...so i suppose i can only get these online??
How is the install in comparision to other FP's?
How much $$$?
Does any other component need to or is recommended to be changed at the same time?
Old Aug 18, 2005 | 05:12 PM
Racetronix's Avatar
OK...so i suppose i can only get these only??
How much $$$?
RX = less labor than generic pump.
Change fuel filter.
Old Aug 18, 2005 | 07:36 PM
Meant to ask where can i get these online only or at local speedshops.......also what kind of injectors do you reccommend (Do they need to be changed at this point....rwhp is at about 320....looking to increase soon though.....
Old Aug 19, 2005 | 01:50 AM
Racetronix's Avatar
You can check our web page for a dealer near you.
Injector size depends on how far you want to go HP wise.
Quickss96
Jan 29, 2016 05:56 PM
Ks0209
Oct 1, 2015 07:32 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
95craz28
11
Sep 12, 2015 07:47 AM
