Gonna try for another stock head LT1 best tomorrow...
Old Jan 9, 2004 | 12:15 PM
Javier97Z28's Avatar
Moderator
I'll be racing at Bradenton motorsports park tomorrow during a track rental.
Gonna hope for a new best.. previous runs below have been in "OK" weather.. this time it will be in the mid-high 50's with humidity in the high 60's for our 4pm-9pm track rental. I'll be able to get over 20 passes, so I'll have plenty of time to mess w/ the car
Only changes are an airbag in the right rear spring, and I may remove my back seat and disconnect my swaybar endlinks..
Still on 245/50/16 Nitto's.. those are what I used to cut my 1.69's last time out. Also I'll be at a stickier track that stays more consistent.
Wonder what she'll run
Old Jan 9, 2004 | 01:12 PM
Cmr0z28's Avatar
Good luck Javier! Hope all goes well and you guys have fun.
Old Jan 10, 2004 | 02:08 AM
kmook's Avatar
Advanced Tech Moderator
It looks like your comming up on ol' Ed (Ed95Pont) he has been at Best 1/4 12.074 Best MPH 115.56 on stock heads.
Old Jan 10, 2004 | 08:23 AM
Z-RATED94's Avatar
Might as well take the front sway bar off, and shed a few pounds. Most likely the end links will snap anyways when you go to take it off. Then again, you probably already know that.
If you doen't mind I'm going to take a guess and say you'll run a 12.15 @ 111 MPH with a 1.64 60ft time.
Let us know how you do.
Old Jan 10, 2004 | 08:50 AM
97Z-M6's Avatar
altjar ran a 11.98 on stock heads.
Old Jan 10, 2004 | 11:05 AM
furely's Avatar
Maybe I should put in a cam and roller rockers, I ran a 12.5 on stock heads, cam, rockers, no boost or juice. Straight bolt on car, and I even spun off the line.
Old Jan 10, 2004 | 12:55 PM
RE AND CHERYL's Avatar
OK...I'll ask, what bolt-on do you have on the car? Thats pretty fast for not tearing into the engine.
Old Jan 10, 2004 | 02:20 PM
atljar's Avatar
I only claim to be fastest full weight 6 speed.
I know of quite a few autos in the 11s, but most have shed some major weight. Not sure if on full weight cars there, but im sure there are some.
Old Jan 10, 2004 | 04:05 PM
96LT14u2Nv's Avatar
good luck. looks like u are coming up on me. dont worry jared, next year i will give u a little better run. 9" and 4.11s/ and 6 speed are coming!!!!!!
oldschool
Feb 9, 2016 09:21 PM
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
MJ_Z28
Aug 8, 2002 09:07 PM
Brian-94TA
Jul 31, 2002 02:52 PM
