Gonna do major tuneup to car, anything else I need
First of all car has 151k miles. I've got a compression tester and gonna check compression to see if the engine needs rebuilt. What is normal psi on a good LT1? Heres the parts I've currently got ordered:
GM Optispark
Jet fan switch
Felpro intake gaskets
IAC valve
And heres the parts I'm also going to get:
Plugs/wires (will be ordering tonight deciding which brands to buy)
Throttle body gaskets (need part # for bottom part of throttle body)
Waterpump (might as well change it when changing opti)
LT4 Knock Module
New vacuum lines
I also have a oil leak around the front of engine haven't really looked to see where its coming from but I'm going to fix it. I'm also going to clean intake good when I take it off. I'm also thinking about getting a new EGR valve but not sure on that.
I put new coil, ICM, o2s, MAF, ECT, fan motors, alternator, 160 thermostat and I thinks thats all in past 6 months. Am I forgetting anything else that I need to do?
GM Optispark
Jet fan switch
IAC valve
LT4 Knock Module
New vacuum lines
well, if you're going to take that stuff off the front. I'd also replace the timing chain & sprockets, as well as the timing cover gaskets and seals. since you're going to take those off, you'll also want to do an oil pan gasket.
all coolant hoses would be a good idea.
What is the minimum compression? Also where can I get the NGK TR55 plugs, does Summit or Jegs carry these? Also plan to do headers in near future so should I get over valve cover plug wires now? Will the stock manifolds cause problems with these? And lastly what is a good timing chain kit that won't cost me an arm and leg?
From: Austin, TX or Texas State University at San Marcos
Stock timing chain is fine replacement but if you are going to go with a cam in the future then you might wanna go with an electric water pump and a cloyes or an LT4 extreme duty(like i did
