Going to the track,need to pick up a couple of tenths
Old Jun 24, 2003 | 11:30 AM
5H9D0W's Avatar
I need to get in the 12's this next time out.I ran my times in my sig before I installed my 3200 and shift kit.What else can I do that dosen't cost over 200 dollars and dosen't take a weekend to do.I ran a 13.5 @99 last time cause my trans was acting up.I fixed it and now and I'm ready to go back.Does anyone have instructions on how I can remove the A/C.
Old Jun 24, 2003 | 11:35 AM
norcalstreet's Avatar
Relocation brackets and control arms. Guarantees to shave a few tenth off your time. I prefer the weld-in relocation brackets since they're cheaper and stronger. Of course the savings don't mean much considering you have to get someone to weld them in.
I have them in stock and can get them shipped out today if you order soon.
Old Jun 24, 2003 | 11:45 AM
5H9D0W's Avatar
Which contro arms do you honestly refer.Can they be here by friday.
Old Jun 24, 2003 | 11:48 AM
Antz97ZNJ's Avatar
Get some good flowing headers and you'll hit 12's no problem...w/ that high a$$ stall you could probably hit it without the headers....
Old Jun 24, 2003 | 11:54 AM
5H9D0W's Avatar
Is there a site that has a list of all the excess weight I can get rid of.I still have my front sway bar on.How is the road/track manners w/ that off.
Old Jun 24, 2003 | 12:19 PM
1994CamaroZ28's Avatar
Depending on how bad you want it can get a ac delete bracket, and remove all the ac stuff, dont forget to take out the spare tire and jack too.
Old Jun 24, 2003 | 12:25 PM
5H9D0W's Avatar
A/C delete bracket..Why would I need one of those
Old Jun 24, 2003 | 12:45 PM
speed76demon's Avatar
I heard taking out the backseat is as easy as loosening up a couple of bolts that has to be good for a few lbs
Old Jun 24, 2003 | 01:50 PM
magius231's Avatar
remove the front sway bar, seats, jack/spare tire,. Pull the belt when you get into the staging area and push your car up through (don't run it long like this, the fuel pump loses output with less voltage to it), LCA relocation brackets, and sticky tires if you can afford em, Ice the intake but be careful of getting water everywhere.
Old Jun 24, 2003 | 01:59 PM
Boxed and tubular are both good. I prefer the boxed but many people prefer the tubular because it's slightly lighter. Strength wise both are far better than stock but the boxed is supposed to be stronger than the tubular.
Sent you a PM as well.
Old Jun 24, 2003 | 02:21 PM
I dunno really heard people talking about brackets before hows your belt gonna fit right if you just take the ac out know what i mean?
Old Jun 24, 2003 | 02:39 PM
magius231's Avatar
thus the reason for the AC delete bracket
Old Jun 24, 2003 | 02:53 PM
Black_Z28's Avatar
Right, that would cause more problems then good. And it isn't going to lower you ETs by much, if anything.
DirtyDaveW
Dec 1, 2016 05:37 PM
Apr 29, 2015 01:43 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
vic_wants_an_SS
Jul 30, 2002 11:38 AM
