Going from synthetic oil back to reg
Old Aug 26, 2007 | 06:49 AM
z2894droptop's Avatar
I have been useing mobile1 synthetic oil in my car for about 4000 miles. Will it be ok to go back to regular oil?
Old Aug 26, 2007 | 07:08 AM
mdacton's Avatar
should be fine.......I only use reg oil, synthetic seems just a waste of money to me with no obvious advantage in my personal use
Old Aug 26, 2007 | 09:29 AM
adamc's Avatar
i hear ppl say things on both sides of the synthetic oil... i dont know for a fact because i havnt dyno tested my own personal car but... i do notice my engine runs alot smoother with synthetic than with regular.. and feels a lil peppier... maybe in part to the smoother running.. i run mobile 1 full synthetic extended something with the syntec stuff i think it costs me 30 bucks for a 5qt. jug not to much more expensive that good regular oil.. especially since you can run the synthetic a little longer it prolly evens out on the $$$
personally i think at this point i like the synthetic.. never know tommorow my engine may fly apart and i may curse it but for now im sold
what im really wanting to do is put the full synthetic royal purple in my transmission... i hear tho that when doing so if u drain and fill your not truely getting all the fluid out so u will have a mixture of both.. whats the best safest way to drain all fluid from transmission and fill back up so there is no mixture
Old Aug 26, 2007 | 10:55 AM
jclark311's Avatar
Its not a problem going back, just change your oil every 3k, if your running a race motor synthetic is probably a better way to go.
Old Aug 26, 2007 | 11:39 AM
CamaroRacing12's Avatar
prolly drop the tranny fluid pan??
Old Aug 26, 2007 | 11:44 AM
mdacton's Avatar
still got the converter and everything on top and inside the valve body..
one of those trans flushers.....but I would not waste my time, alsy I think the trans flush machines strain the pump and I will never use one. We have one in the shop and alot of trans take a dump shortly after using it
Old Aug 26, 2007 | 02:00 PM
11secgen's Avatar
just change the trans fluid twice to remove almost all of the old fluid.make sure to drive the car around for a little while after the first fluid change.
Old Aug 26, 2007 | 02:26 PM
adamc's Avatar
lol i was afraid of that
that royal purple is expensive.. but if its the only way to get all the old fluid out what the hell
rideordie
Nov 5, 2019 04:52 PM
jj71787
Jan 31, 2015 10:20 PM
Scottylt1
Jan 8, 2015 02:48 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Scottylt1
Dec 4, 2014 12:31 PM
