going to scann my car in the 1/4 Mi what should i record?
Old Apr 28, 2004 | 11:16 AM
93transam1234's Avatar
I am going to the track this weekend to do some 1/4 mile runs with my Auto Tap hooked up.
I want to know what sensors and stuff i should record to make sure she is running in tip top shape.
Old Apr 28, 2004 | 11:41 AM
GreenDemon's Avatar
As many as you can.
Definitely o2s
All your intake and tb sensors would be helpful too, to see if there's any fluctuation.
See if the pcm is retarding timing due to indicated knock or temp, etc.
Old Apr 28, 2004 | 12:17 PM
how do i check if the timing is being retarded
Old Apr 28, 2004 | 12:33 PM
AutoTap will show you the amount, if any of "knock retard".
A better approach might be to delete the things you don't want on a 1/4-mile run, like "desired idle", A/C pressure, EGR duty cycle, EEC duty cycle, IAC counts, . Do not record both voltage and temperature for things like IAT and coolant. Record only the temp. That deletes an uneccesary column.
The things you definitely need:
RPM
MPH
Coolant temp
IAT
MAP
MAF
BAR
TPS %
TPS volts
Cell #
BLM-left
BLM-right
O2 - left
O2 - right
Pulse width - left
Pulse width -right
Spark advance
Knock retard
Old Apr 28, 2004 | 12:44 PM
FRED
Could i send you a copy of my log for you to review in cvs format?
I am pretty sure it is running ok just want to make sure befor i put my $$ into new mods that i dont need to work on anything else.
Last run i ran a 13.95 at 98 MPH with LT, Cai, LT4 km, 2:73 gears
I will be putting on new plugs and wires for the next run
my next mods are LCA, Sway Bar, TQ Arm, 3:73 gears, 3200 stall
I want to be in the low 13's by the end of summer
Old Apr 28, 2004 | 12:59 PM
Yes.... if you send me a .csv file, I will look it over. I just ask that you be patient... seems like I am spending more time answering questions and looking at data logs than I spend on my own car - which is sitting on blocks.
Old Apr 28, 2004 | 01:12 PM
well
If you need some help on the weekend i wouldnt have a problem comming up and helping you. You have been the only one to help me out a few times, and saved me a ton of $$$
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
