GM847 valvetrain?
Old Jul 12, 2005 | 12:16 AM
jninan2k2's Avatar
GM847 valvetrain?
Well I am going with the gm847 camshaft soon and I am a bit in the dark with what I should upgrade to go along with it. I know I need 1.6 rr's and some valve springs, but thats about it. I need to know which valve springs more specifically...I know I might not need to get hardened pushrods because I have been told 1994's came with them. Any advice would be nice.
Thanks,
Jacob
Old Jul 12, 2005 | 12:24 AM
'94 Bad A Z28's Avatar
Re: GM847 valvetrain?
HARDENED PUSHRODS
My '94's "Hardened Pushrods" http://img.photobucket.com/albums/v1...o/DSC02041.jpg
A good set of valve springs, like the Comp Duals. And you do not NEED 1.6rr's you can get whatever size you want, and can afford the valvetrain for.
Old Jul 12, 2005 | 12:39 AM
jninan2k2's Avatar
Well I know I necessarily don't have to get some 1.6 rr's, but I'd like to get the most out of my cam. I know the 1.5 ratio would hold out some power I could gain. Anyways, I know that crane makes a certain dual valve spring. Anyone happen to know the exact name?
Thanks,
Jacob
Old Jul 12, 2005 | 05:26 AM
Capt'n Two Rotors's Avatar
I have the 847 with Stock 95 pushrods for quite a while and no problems yet, get NSA rockers (I have the CAt 1.6's) and get the guide plates from Combination motorsports($12) You have to use longer studs for the guide plates so I would suggest getting the 7/16 since you have to change rockers and studs anyway. I used the Comp 987 Dual valve springs but I think you would be better off using the 918's they are a beehive single.
HectorM52
Jul 30, 2017 11:46 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
LT14LIFE
Feb 9, 2015 09:35 PM
cenman
May 19, 2003 07:11 PM
cenman
May 16, 2003 09:01 PM
