LT1 Bottom ends same as 86 up sbc??
Old Jul 12, 2005 | 05:28 AM
Capt'n Two Rotors's Avatar
Are the lt1 crank and rods the same as on every other 1 piece rear main seal bottom end?? Also are the rods the same as a 1gensbc? Are the pistons any thing special?
Old Jul 12, 2005 | 06:45 AM
SStrokerAce's Avatar
Re: LT1 Bottom ends same as 86 up sbc??
Basically yes... the crank for the LT is not the exact same as every other 1 piece rear main seal stock GM crank. The rods in the later LT motors are Powdered Metal where the early rods were basically the same as the SBC rods. I'm not sure who made the old SBC cast pistons but the new ones are made by Mahle and are pretty good for stock units.
bret
Old Jul 12, 2005 | 07:24 AM
So can I use the rebuild kits for any 1 piece rear main SBC or does it have to be specificly for an LT1.
Old Jul 12, 2005 | 07:46 AM
Some info that might help: http://www.automotiverebuilder.com/ar/ar99928.htm
Old Jul 12, 2005 | 08:00 AM
So according to that article you can use a regular SBC 1 pice you just have to balance it. And I know th lt1 came with powdered metal rods, but are they interchangeable with every other SBC? And it seems a 350 piston is a 350 piston.
D1SC383LT4
Jan 1, 2016 01:56 PM
sscott
Jan 17, 2015 04:30 PM
Killer94z
Jan 13, 2015 12:06 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
