GM847 dyno troubles... need some advice
Old Jul 8, 2007 | 12:39 PM
  #16
speed_demon24's Avatar
Originally Posted by SS MPSTR
58 versus 54 isn't going to make that big of a difference....certainly not going to put the compression too far out of wack for that cam. It is too low for optimization, however IMO. What's the quench? What final DCR did you end up with?
If hes using a stock thickness gasket his compression is only going be 10.0:1 which will kill his torque. Hopefully he atleast used a thin gasket to get it back up to stock.
Old Jul 8, 2007 | 12:44 PM
  #17
SS MPSTR's Avatar
yep. didn't read all the specs, but with a build like this, I'd hope some attention was paid to the quench and DCR. I ran a cam similar with the same compression (big mistake, another story), and made decent power, so it can be done. Is it preferred? Nope. Will it detonate? Not likely.
Old Jul 8, 2007 | 12:52 PM
  #18
trax's Avatar
Originally Posted by SStrokerAce
Yeah, this is a case where just switching the valvesprings on the first setup would have you much farther ahead,
Bret, Comp recommended the 987's on that first setup. For the second cam, I spoke with Cam Motion first to determine the seat pressure that I would need, and then talked with Comp to determine what spring to go with that would meet those requirements. What should I have used instead?
considering your down almost 20 ft lbs at peak and 40 ft lbs @ 3000! Just wondering does the car feel slower untill you "get on the cam"?
Yes, definitely. The second setup feels very slow until about 3000 RPM.
Old Jul 8, 2007 | 12:54 PM
  #19
trax's Avatar
Also, I corrected an error in the first post. The chamber size is 54cc, not 58cc. I am also using an Impala head gasket.
Keep the replies coming guys. I am determined to figure out what is wrong with the setup.
Old Jul 8, 2007 | 01:04 PM
  #20
CamaroSS30thAnn's Avatar
The GM847 is a higher end cam anyways. You really wont feel much of the power untill u get over 3k moreso over 4k. Thats when that cam really takes off. Hence y auto cars go with large stalls so that they stay in that power band
The 503 is a great all around cam. Good low great mid and decent top end. Its all on what u want out of your settup. Great for a stock or mildly headed car and makes good power.
Since most of the cars in my area are LS1s and a very small bunch of fast 4 bangers with ALL TOPEND i went with a cam that will perform up there. And its not really outrageous
just ask yourself on what u want out of your car and who your competition is
and again , when racing how often are u gonna be below 3k? Unless u want a street cruiser and dont want to be revving to 6800 then the gm847 isnt the right cam for u.
Honestly id check what u knwo is already the problem. Do somthing about your rear end and recheck the valvelash. On stock cubes there is no reason y you shouldnt be making 400rwhp.
Old Jul 8, 2007 | 01:10 PM
  #21
SS MPSTR's Avatar
Originally Posted by trax
Comp recommended the 977's on that first setup.
those springs will work fine with that first cam.
Old Jul 8, 2007 | 04:06 PM
  #22
trax's Avatar
Crap, my typo's are killing me today
Comp recommended the 987 on the first cam, 977 on the second cam.
From Comp's valve spring chart:
987
1.800" install height
370 lb spring rate
121 lb @ 1.800" height
977
1.850" install height
441 lb spring rate
155 lb @ 1.850" height
Old Jul 8, 2007 | 04:23 PM
  #23
987
370 lb spring rate
977
441 lb spring rate
You were definatly getting valve float after 6200 with the 503, and it looks like you might be getting valve float at 6500+ with the new cam, a 1.5" diameter spring has to be heavy as hell along with the retainer.
Old Jul 9, 2007 | 01:55 PM
  #24
SStrokerAce's Avatar
I forget exactly but the mass difference of a 977 vs a beehive is about double!
No doubt you are feeling the lack of midrange TQ with the new cam, you just can't have that much duration that late and make any midrange TQ.
Bret
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
fift5
11
Oct 1, 2015 10:31 AM
