GM847 Dyno Numbers
GM847 Dyno Numbers
Today i dynoed my Cam only LT1 motor before it goes up for sale this winter, The numbers seem to be normal for the mods, im sure it could be higher if i got the combo dyno tuned with a e-water pump and maybe some true duals but i have a 396 in the works so i looking forward to bigger and better things next spring. Mods & track times are below
Mods
Stock Shortblock
Stock Unported Heads
Gm847 Cam
Comp 918 Beehives
Comp 1.6 Pro mags
Comp Locks & retainers
LT4 Timing set
#38 injectors
Holley 58mm TB
K&N cai
Pacesetter LT headers
Hooker Catback
Msd Digital 6
TR55 Plugs
Msd 8mm wires
LT4 Km
!A.I.R
!EGR
Madwolf Tune
Mods
Stock Shortblock
Gm847 Cam
Comp 918 Beehives
Comp 1.6 Pro mags
LT4 Timing set
#38 injectors
Holley 58mm TB
K&N cai
Hooker Catback
Msd Digital 6
TR55 Plugs
Msd 8mm wires
LT4 Km
!A.I.R
!EGR
Madwolf Tune
Nice. On an initial run, my GM847 heads/cam setup did 371/345 SAE with:
Clogged air filters
3" vacuum at WOT
11:1 AFR at 6500 RPM
I think it's a safe bet that it can break into 380's once I iron out those issues. Once school is out I'll do some more datalogging and get another baseline.
Clogged air filters
3" vacuum at WOT
Joe Brodman
Jul 24, 2002 05:24 AM
Are you selling just the motor or the whole car?
