GM847 Cam Install Questions
Old Dec 31, 2003 | 10:23 AM
athens96ta's Avatar
Going to start the 847 cam install this weekend and would appreciate any advice on "gotcha's" or things I should measure. I will be staying with the heads in my sig which have the LPE double valve springs and titanium retainers. I already have hardened push rods and am running stock lifters. Should I replace the lifters? I am using 1.6 roller rockers. Thanks in advance...and I'll post dyno numbers after I get it tuned.
Loren
Old Dec 31, 2003 | 10:29 AM
Grease's Avatar
If you can, degree the cam. Intake centerline on the GM847 is 107 degrees BTDC. with the regular marks mine cam to 102 degrees, I had to retard it 4 degrees to get it as close as I could.
I use stock replacement lifter too, however I have 1.5 roller rockers. Comp Rs in your case would be better.
Old Dec 31, 2003 | 10:50 AM
athens96ta's Avatar
Grease,
I am the guy in Tulsa. I think I spoke with you on the phone before I purchased the cam...sorry...not good at remembering names. If you are the person I spoke with, I still have your contact info at home I believe. I may give you a call if it's ok. Do you think I will have any clearance issues with the 1.6 RR's. Also, I want to degree the cam with the heads on the car. Do I really need to take the heads off to degree accurately?
Thanks,
Loren
Old Jan 5, 2004 | 09:27 PM
LPE Z convt's Avatar
Hey Loren This is chris i spoke with you on the phone about the 847 cam also ... Glad to see you went with it i can't wait to see the #s you make on the dyno.... Good Luck...
LT14LIFE
Feb 9, 2015 09:35 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
