Gm847
Old May 26, 2004 | 06:29 PM
blackz6sp's Avatar
Gm847
Which injecters need to be used on a NA lt1 stock bottom end with heads and GM847 cam??
Old May 26, 2004 | 06:31 PM
97SS0594's Avatar
i would think your stockers would be ok.
Old May 27, 2004 | 08:47 PM
blackz6sp's Avatar
Does everyone agree. Anybody know from exerience?
Old May 27, 2004 | 08:55 PM
besz28's Avatar
go up to 30lb ones. cheapest place i found them is gefracing.com
Old May 27, 2004 | 09:38 PM
94_Camaro_LT-1's Avatar
I have both the cam and accel 30lb injectors for sale if your intrested... $300 plus shipping for both cam has less then 4k on it and the injectos have about 14k.
Old May 27, 2004 | 09:47 PM
blackz6sp's Avatar
Already have the cam. Just looking for info on the injectors
Old May 27, 2004 | 09:56 PM
simple's Avatar
hey thats my line
www.gefracing.com
its easier to take fuel away then it is to add it
Old May 27, 2004 | 09:57 PM
OK well if you decide on those injectors LMK helped me out with my fuel curve by stepping up
Old May 27, 2004 | 10:07 PM
Somnambulist's Avatar
stick with your stock injectors...no need to go with 30#ers until you get your heads done...
Old May 27, 2004 | 10:10 PM
simple's Avatar
says in the 1st post, he has heads.......i assume he meant P=P stockers.....?
if not just stick with the stock injectors
Old May 27, 2004 | 10:14 PM
ohh didnt even catch that part....
yeah go with the 30#ers depending on your port job...
Old May 27, 2004 | 10:25 PM
blackz6sp's Avatar
Yeah the heads are an LT1 cast with a full port by Advanced Induction.
Old May 27, 2004 | 10:46 PM
Fastbird93's Avatar
30# should do you fine. SVO's area actually about a 31.6 rating on a GM system, so there's a bit extra.
LT14LIFE
Feb 9, 2015 09:35 PM
med_reject
May 17, 2004 05:33 PM
nhodge93
Apr 6, 2004 05:42 PM
nhodge93
Apr 1, 2004 02:39 PM
AdamZ1LE28
Mar 18, 2004 04:20 PM
