GM performance oil pump
Has anyone used the GM oil pump with the white spring? GM PART # 12555884? They claim it holds 65-70psi and operating speed. Would this be over kill for my car when i do my cam swap? for some damn reason i have a drop in presure at 4k rpm at wot i need to fix.
Re: GM performance oil pump
Originally Posted by shoebox
Not sure what pump that p/n is for, unless it is for the SBC LT-1 (not LT1, like we have).
You want the stock 3/4" inlet pump with the white spring.
