GM Opti-spark Alternative
Old Apr 23, 2005 | 06:05 PM
Jeremy_30th's Avatar
Not sure if anyone has seen it but MSD has one now. Cheaper to MSD @ Summit
Old Apr 23, 2005 | 06:19 PM
moparman's Avatar
Talking Re: GM Opti-spark Alternative
Only a couple dozen people have seen it and posted about it. It's a cap and rotor only.
Old Apr 23, 2005 | 08:40 PM
BLinindoll's Avatar
Yeah, normally when you buy replacement opti it doesn't come with the cap and rotor. It only comes with the internals. A guy I know though has a part number for AutoZone where they screwed up and it gives you both the opti and the cap and rotor for about the same price. Pretty cool, but I might just go ahead and buy the GM one anyway. How come the vented one is $100 LESS than the non vented one??? It doesn't even make sence to get the non vented one. Even after the cost of the vacuum harness for the vented one, it's still cheaper then stickin with the frigged up non vented one.... WTF?!?!?!
Old Apr 23, 2005 | 08:46 PM
100Bucks's Avatar
If you have the old non-vented opti, you can't change to the vented opti without some serious engine modifications.
It's a big step.
Old Apr 23, 2005 | 10:14 PM
Randy L's Avatar
Hey, I just got the whole distributor from Summit on line for $289. When I opned the box, it was the whole distributor...INCLUDING the cap and rotor.
Old Apr 23, 2005 | 10:54 PM
$289 is the Summit price for the FULL vented Opti. You could have bought it from Dal Slabaugh or Jason Cromer for quite a bit less. Check out Shoebox's Tech Pages for "Where to buy GM parts". I think Dal is around $229 and Jason at $239 for the same part #.
http://shbox.com/1/4th_gen_tech1.html
Old Apr 24, 2005 | 06:35 AM
BLinindoll's Avatar
Yeah, too bad I have the non vented one.... $389 in summit.... hopefully it's not the cause of my problem.
Old Apr 24, 2005 | 09:58 AM
moparman's Avatar
You can probably beat that price by checking with Dal or Jason.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
