GM guideplates
GM guideplates
Hey guys I cant figure out whats the correct part number.
I need Guide Plates and I by reading this posts I know GMPP guide plates are the only way to go BUT is this the correct part number?:
GM OE part # 14011051
On LS1speed.com, LT1 section they list:
93-97 LT1 CC4808-8 GUIDE PLATES FOR USE WITH 5/16" PUSHRODS $22.99
AND at gmpartsdirect.com I found this for par #14011051:
GM PART # 14011051
CATEGORY: Engine Valve Push Rod Cover Guide
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $2.91
OUR PRICE: $2.04
DESCRIPTION: PUSHROD GUIDEPLATE
This hardened steel guideplate is used with aluminum Bow Tie V6/90º cylinder heads with screw-in rocker arm studs. Technical Notes: Use on cylinders #1, 2, 5 and 6. Grind guideplate to clear valve cover hold-down bolts. This guideplate is identified by the stamped number "05."
Can anyone tell me whats the correct GMPP part number?
GM PART # 14011051
GM LIST: $2.91
OUR PRICE: $2.04
onebadponcho
Oct 20, 2003 01:44 AM
MattysTA
Oct 5, 2003 08:53 AM
94formulabz
Aug 15, 2003 08:50 PM
