GM 847 Too Radical?
Old Apr 21, 2004 | 07:48 PM
Kryckter's Avatar
GM 847 Too Radical?
I was wondering what you guys think about the GM 847 cam. I have a 355 LT1 and want to do ported heads with that cam and some 30 lb. injectors. Do you think this is too radical for a daily driver? I really dont care about driveability but only too much stress and it would wear out parts and break too fast. I can live with a big cam for daily driving but is it too big for the stress on parts. I know I would have to get better springs and such, But I'm thinking it may be wise to just port my heads and get a bigger TB or something and not worry about the cam. Would there be that big of a gain from my 224/230?
Thanks in advance!
Old Apr 21, 2004 | 07:51 PM
1994TransAm's Avatar
i loved the cam untill my fuel pump died!!!!!!
i used to have a 224/230.............
Old Apr 21, 2004 | 09:13 PM
bunker's Avatar
mine is fine, I daily drive her through rush hour traffic all day, once you learn how to drive then its easy as pie, tunning makes a night & day difference is all I have to say, but for me I could use a bit more drivability even though this is plenty, I'm saying this because I'm bumper to bumper traffic all day
Old Apr 21, 2004 | 11:24 PM
engineermike's Avatar
If you're worried about reliability, then it won't be a problem. The
Crane cams have nice, slow ramp rates for a quiet, long-lasting valvetrain.
Of course, driveability will suffer. You'll lose some low-end, idle will be rough, and it will run hotter. If you can put up with that, then get it.
I had that cam in a carb'd, full-weight '89 Firebird with an 11/1 383, AFR 210's, Victor Jr., and SLP shorty headers and it ran 11.09 at 122.5 mph.
Mike
Old Apr 22, 2004 | 11:24 AM
Kryckter's Avatar
The main worry I have is excessive wear on the valve components! I really dont want to wear down the valve springs and have to be replacing stuff too often!
Old Apr 22, 2004 | 01:10 PM
Elysian's Avatar
With a decent set of lifters, matched springs, titanium retainers, hardened pushrods, and some 1.6 rockers, you shouldn't have any trouble with wear. There are guys all over this forum who run that cam in their daily driver. As was previously mentioned, the fuel pump may be a problem after a while, but they sell replacement units for that for about ~$200 or so that can handle 800hp. I'd be impressed if you could hit that number with only the cam.
Old Apr 22, 2004 | 01:18 PM
Brettinator's Avatar
Mike
Mike - Had no problems here with driveability, low-end is obnoxiously strong, idle cured with proper tuning, never ran hotter either. Did this cam do all that crap in your stroker after installing it? Nice ETs by the way on your 89'.
Kry - Don't do it halfway dude, if your going to go with a good cam like this one, do your valvetrain. Porting your heads, 30'lb injectors and bigger throttle body is not going to give you what a good cam will, sure anything helps but your out of sequence a little. Cam first, valve train, heads, intake, TB, injectors, etc etc. Start at the brain which is your cam.
Old Apr 22, 2004 | 01:42 PM
Vendetta's Avatar
847 is a great cam if you've got heads. awesome topend power. it might not be the best for a daily driver but it would put out great power if you had ported heads with your 355. you would definitely want to strengthen up your valvetrain a bit though, like these guys have already said. good luck, let us know what you do!
Old Apr 22, 2004 | 01:47 PM
bunker's Avatar
as mentioned before, its real easy on your valve train, I need titanium retainers
Old Apr 22, 2004 | 03:00 PM
ANY cam with more duration will have less low-end, rougher idle, and add more heat to the cooling system.
So your cooling system may be good enough to prevent it from running hotter, but the larger cam WILL lose low-end and idle quality.
My power brakes worked and it was tolerable, but definitely choppy.
Mike
sleeperZ96BT
Sep 9, 2015 08:28 AM
BLK1997Z28
May 7, 2015 03:01 PM
737drivr
Feb 20, 2015 12:00 PM
CARiD
Feb 9, 2015 09:35 AM
Schurters LT1
Advanced Tech
Apr 7, 2003 08:46 PM
