HELP with cloyes set? & 847 cam
Old Apr 6, 2003 | 06:17 PM
Schurters LT1's Avatar
i have a 95 T/A vented opi
i have put in the 847 cam and the thrust plate. The cam gear is hitting on the thrust plate bolts on the back side ?
part # 9-3145
do i need a spacer?
do i have the wrong gear set?
i phoned jegs and they said that i have the right part? i think that the part box is right but the chain is wrong what is the part number on the gear set?
the oe cam gear is just a bit biger( like 2 hairs) and the oe cam gear fits fine on the 847
thx
Old Apr 6, 2003 | 09:46 PM
OneFlyn95z28's Avatar
Hmmm...
no problems here but I thing I used a Comp Cams gear set.
Where is it hitting? Can it be cleaned up to clear or will it be to much to take off?
Could always take it to a machine shop and have it clearanced.
Good luck.
Old Apr 7, 2003 | 06:47 PM
got it!!!!
Old Apr 7, 2003 | 08:46 PM
4drLT4's Avatar
How long is that dowel pin on the 847 cam? It's gotta be .620"....if much longer, you will have a scenario EXACTLY like the one you are describing.
HectorM52
Jul 30, 2017 11:46 AM
chuyz28
Jan 15, 2015 04:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
dobe
Jul 31, 2002 01:28 PM
