GM 847 Cam question
Old Nov 12, 2004 | 12:39 PM
  #16
The Cartel's Avatar
Re: GM 847 Cam question
what's TEA? Do you have a website?
Old Nov 12, 2004 | 01:10 PM
  #17
WinnipegGTA's Avatar
www.totalengineairflow.com
Old Nov 12, 2004 | 01:37 PM
  #18
97bowtie's Avatar
Originally Posted by WinnipegGTA
LT1 Stage 2
Lift Intake Exhaust
.100 68.6 56.1
.200 139.6 118.8
.300 199.8 164.7
.400 240.9 198.5
.500 267.6 220.0
.550 269.9 229.4
.600 270.0 237.5
LOL, you're dreaming. Those exhaust numbers aren't even close. Even if the exhaust side was flown with a pipe, those are too high.
Old Nov 12, 2004 | 01:38 PM
  #19
97bowtie's Avatar
I dont think a company like TEA would falsley advtise flowratings
It's not a matter of false advertising...I'm sure the heads "made" those exhaust flow numbers, but the method they used to get them and the calibration of the flowbench are questionable.
Old Nov 12, 2004 | 01:56 PM
  #20
Why do you think its false advertising. They seem to have very similar numbers for stg 2 as LE does, just the exhuast see's the full CNC treatment as well.
Old Nov 12, 2004 | 02:04 PM
  #21
Gripenfelter's Avatar
There is no way the exhaust flow is that high. Probably a typo on their site. Davenport Racing in Calgary carries TEA heads and the flow numbers they advertise are no where near that.
Email TEA.
Old Nov 12, 2004 | 02:06 PM
  #22
WS Sick's Avatar
I've seen ported Track ones with less flow than that on the exhaust.
Old Nov 12, 2004 | 02:07 PM
  #23
Camaro_Maniac63's Avatar
TEA flows their heads with a pipe for the exhaust, that is the reason for the higher numbers...
Old Nov 12, 2004 | 02:29 PM
  #24
Ok so realistically what would they be like then?
Old Nov 12, 2004 | 02:35 PM
  #25
Looking at how they did on the intake side, I'd *guess* about 40-45 cfm lower on the exhaust side.
Old Nov 12, 2004 | 02:51 PM
  #26
The Cartel's Avatar
Originally Posted by Z95m6
I thought i always heard you want at least .030 less lift than what your springs can take. I also think if you push the springs to their limits they have a very short life span. Not a good idea.
You got me thinkin. So I called Compcams for advice and they said that there is actually 60 thous. more in their springs. As I figured their underated. Probably for people like me, if says it's good to .600 that's what I'm pushin em to
Jason
Old Nov 12, 2004 | 03:00 PM
  #27
Just a compare to LE2 heads i made up. Again the TEA heads exhaust are off
LE2 vs TEA stg2
.2 136/102
.3 192/137
.4 238/164
.5 265/183
.6 271/188
.2 140/119
.3 200/165
.4 244/199
.5 268/220
.5 270/229 <---.550 lift
.6 270/238
Old Nov 12, 2004 | 05:54 PM
  #28
12SCNDZ's Avatar
Yes, the 847 is made by Crane. Yes, the 847 is backordered indefinitely. I had my supplier check on the Crane with the same numbers, and it cost $85 more than the 847. Gee, for once something with a GM part number is CHEAPER than something aftermarket . I've had my 847 ordered for 2 months now.
Frank
Old Nov 12, 2004 | 06:06 PM
  #29
The Cartel's Avatar
Did they give you any time frame? Jason could'nt give me one. I can't handle 2 months.....
Old Nov 12, 2004 | 08:21 PM
  #30
97Z-M6's Avatar
Would this cam work well and compliment a set of Stage 2 TEA LT1 heads w/1.6rr's? Max lift on the cam would be .575/.595 with 1.6rr's. Its in those lift areas that the TEA heads have the best flowrates. I believe 270cfm intake and close to 240cfm exhaust. Thanx for any adivice. Cam info is below.
your low and mid lift numbers are where your power is made not a 600 lift.
but those numbers about 45 to 50 cfm off
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
