Gm 847
Old May 10, 2006 | 08:33 PM
976speed's Avatar
Gm 847
what would it be like with a gm 847 cam with stock heads on a 97 Z28 M6 with longtubes and CAI? i want to do either an 847 or comp 306, i dont drive it daily and i will eventually upgrade the heads.
Old May 10, 2006 | 08:37 PM
zx1216's Avatar
Re: Gm 847
do a search, its done all the time, expect to spend over $1000 to do it right with the new valvetrain to support the cam. mine drives fine and doesn't really surge at all, thats in the good tune...
Old May 10, 2006 | 08:45 PM
EODUSMCR's Avatar
Re: Gm 847
there is a guy locally that did that but, you will need to add the following to make it work... roller rockers of some type preferebly 1.6s and bigger springs because your stock springs won't be able to handle the big lift of the 847. Even if you go with the 306 you still need to change the springs and would not a good idea to do either cam without the roller rockers. If you had the cash go with one of the LE heads/cam packages.
Old May 10, 2006 | 08:49 PM
blackz97's Avatar
Re: Gm 847
www.atljar.com check out that guys website he had that setup in the past and its pretty well documented there.
Steve
Old May 10, 2006 | 09:01 PM
camaroKid223's Avatar
Re: Gm 847
with a 847 2.73's and the mods in the sig (not on the spray) went 12.4 runs great
sleeperZ96BT
Sep 9, 2015 08:28 AM
Metlegleo
Mar 15, 2005 11:16 PM
badblackta
Mar 10, 2004 09:18 AM
Camaro_Maniac63
Feb 9, 2004 04:26 PM
Mystic97Z
Dec 16, 2003 05:00 PM
