What springs w/ GM 847 Cam?
Old Feb 19, 2004 | 08:47 AM
Metlegleo's Avatar
What springs are you running with the GM 847 cam w/ 1.6 rockers....do they require any machine work? We swapped cams from a Hotcam to the 847 on my brother-in-laws car. Used to run the LT4's and trying to get a spring that fits without additional machine work.
Thanks,
Mark
Old Feb 20, 2004 | 12:32 AM
Metlegleo's Avatar
ttt
Old Feb 20, 2004 | 12:57 AM
atljar's Avatar
K-motion k-800 with no machine work. Do need to shim them accordingly.
Old Feb 20, 2004 | 01:11 AM
NAZTLT1's Avatar
Same springs my head prep guy used for this cam.
Old Mar 11, 2005 | 10:46 PM
JASON96Z's Avatar
Re: What springs w/ GM 847 Cam?
Do these springs come with shims?
Old Mar 15, 2005 | 11:16 PM
atljar's Avatar
No the springs are just springs. You will need retainers, 10 degree locks and then need to measure your installed height, figure out your pressure needed and shim accordingly
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
grabbem88
Feb 22, 2015 11:16 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
