gm 847 in 383, CAM HITTING ROD
Old Apr 7, 2007 | 09:36 AM
  #16
SS RRR's Avatar
Thumbs up
Originally Posted by rskrause
Most of the bottom end parts people buy are way overkill anyway. How many people have seen stock crank or rod breakage? Actually, the stock stuff is good. OTOH, if you are talking a hi-po build (not a mildly modified motor) better parts are needed. There is a difference between ultimate mateiral strength and utility of a part. There are QC and inspection issues as well as finishing. The good parts have spot on dimensions, are straight, flawless material, and so on. Politics aside, what you need depends what you are building.
WRT the Compstar line, poltics aside, what Callies is doing makes sense. The forgings are Chinese but they are finihsed and inspected here. Eagle also has a good rep. I'd stay away from the others, as much because of lack of familiarity asanything else. For me personally, USA all the way.
Rich
Thank you, sir. That's exactly what I was looking for.
I'm using a small base circle solid roller cam with 250/500 type spring pressures. Probably will be spun to around 6800rpm. Would you worry?
Old Apr 7, 2007 | 11:48 AM
  #17
rskrause's Avatar
Moderator
I would consult with the cam grinder. My own inclination is to make the rod fit, not the cam as the SBC is small diameter in the first place.
Rich
Old Apr 7, 2007 | 01:13 PM
  #18
SS RRR's Avatar
Rich
The rods fit well. I changed up from Eagle to CompStar because my builder didn't like how tall the rod bolt profile was on the Eagles and felt too much material had to be taken off the pan rails to make them work. After lining up the two rods together the CompStar profile is significantly shorter.
Old Apr 7, 2007 | 06:32 PM
  #19
96 mikez28's Avatar
Interesting, are the 5.7" or 6" rods?
Old Apr 7, 2007 | 06:42 PM
  #20
rskrause's Avatar
Moderator
The Eagles have mediocre clearance.
Rich
Old Apr 7, 2007 | 09:39 PM
  #21
ctools9's Avatar
i clearenced 3 rods and all is fine, thanks guys
Old Apr 8, 2007 | 03:36 AM
  #22
SS RRR's Avatar
They are 6".
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Queens94z28
Nov 20, 2014 06:03 PM
