glowing header tubes
Old Nov 4, 2005 | 08:17 PM
1badasZ's Avatar
Angry glowing header tubes
ok i had a terrible miss...to the point where the car would bout cut off when you try to take off....saw some of my plug wires arcing and so i figured it was time to change em. i took all of the old plug wires off and 2 of them were burned really bad. so i swapped out plugs and put some taylor wires and heat shields on. i was holding the throttle at about 2500 to see if there was anymore arcing and now i have a few header tubes glowing...what do i do next?
Old Nov 4, 2005 | 08:21 PM
OBE1 95Z28's Avatar
Re: glowing header tubes
If the car's sitting still for 10+ minutes with the motor reving your headers are going to glow.
Old Nov 4, 2005 | 08:31 PM
1badasZ's Avatar
but if that was the case wouldn't all of them glow? only certain tubes are glowing
Old Nov 4, 2005 | 08:43 PM
97TransAm's Avatar
Because of the wire problems I'm thinking that there is a typical engine rich condition, plus excess fuel igniting in the tubes will cause the glowing.
Check that all plugs are connected and functioning correctly.
But for further insight:
The Debate.
Old Nov 4, 2005 | 08:54 PM
OBE1 95Z28's Avatar
Did the plugs look evenly "sooted" or different, pointing to certain cylinders firing differently?
Old Nov 4, 2005 | 09:03 PM
1badasZ's Avatar
well the ones where the wires were burned were probably the worst ones
Old Nov 4, 2005 | 09:12 PM
blind527's Avatar
I thought glowing tubes meant the engine is running too lean..
Old Nov 5, 2005 | 11:35 PM
1badasZ's Avatar
according to the scanmaster its running to rich
Old Nov 7, 2005 | 07:15 PM
ZMAN Z28's Avatar
The only couple of times I have seen glowing headers is when the valves were adjusted too tight. But that's not your case.
ZMAN
Old Nov 17, 2005 | 06:22 PM
Dave88LX's Avatar
ZMAN
Hopefully it's mine. Will check out the other thread.
Critter
Jul 7, 2015 08:33 PM
MDZ28
Exhaust System
Jun 2, 2015 09:48 PM
drptop70ss
May 4, 2015 08:22 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
